bossjedizohan
When using Nvenc to encode streams, a pretty hefty audio delay/sync issue occurs (skip to about 1:00 for a good example) http://www.twitch.tv/bossjedizohan/b/500381855
While just adding a basic delay to the audio might work, I've noticed that the desync duration isn't constant. Sometimes it's a second or so, other times it's closer to 3 seconds.
Any advice on how to fix this?
Is this a known issue that will be patched soon?
Issues aside, I'm really happy that Nvenc is now an option with OBS.
If you're looking to try it but don't have a Quadro or License Key, download follow the instructions here to get a DLL with the license built in: viewtopic.php?f=20&t=10234&hilit=nvenc+license&start=10#p57445
Thanks.
Thanks.
