Open Broadcaster Software v0.465a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
CPU Speed: 3392MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
Windows Version: 6.2 Build 9200
Aero is Enabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 560 Ti
Video Adapter Dedicated Video Memory: 2096562176
Video Adapter Shared System Memory: 2147364864
Adapter 2
Video Adapter: Microsoft Basic Render Driver
Video Adapter Dedicated Video Memory: 0
Video Adapter Shared System Memory: 268435456
Multithreaded optimizations: Off
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Using 7.1 surround speaker setup (experimental)
Using auxilary audio input: Microphone (2- Logitech G930 Headset)
Audio Encoding: MP3
bitrate: 320
Using graphics capture
DShowPlugin: No audio pin, result = 80004005
device: Decklink Video Capture,
device id (null),
chosen type: HDYC, usingFourCC: true, res: 1280x720 - 1280x720, fps: 59.9402-59.9402, fourCC: 'HDYC'
Using directshow input
Video Encoding: x264
fps: 30
width: 1280, height: 720
preset: veryfast
CBR: no
max bitrate: 3500
buffer size: 3500
quality: 10
Total frames rendered: 468, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 320
device id (null),
fps: 30
preset: veryfast
CBR: no
max bitrate: 3500
buffer size: 3500
quality: 10
device id (null),
Total frames rendered: 13982, number of frames that lagged: 1 (0.01%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 4.138 ms] [avg calls per frame: 1] [children: 87.6%] [unaccounted: 12.4%]
| scene->Preprocess - [18.6%] [avg time: 0.77 ms] [avg calls per frame: 1]
| video encoding and uploading - [69%] [avg time: 2.856 ms] [avg calls per frame: 1] [children: 42.4%] [unaccounted: 26.7%]
| | CopyResource - [0.0483%] [avg time: 0.002 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [19.8%] [avg time: 0.82 ms] [avg calls per frame: 0]
| | call to encoder - [22.5%] [avg time: 0.93 ms] [avg calls per frame: 0]
| | sending stuff out - [0.0242%] [avg time: 0.001 ms] [avg calls per frame: 0]
