NovaNationStream
I have been using 2 copies of OBS one to record using my nvenc and then one to stream to twitch...
It was all gravy until i did an update on my gfx card that my system wanted for adobe premiere to run properly...
So
These are the settings I am using, these are the same as they was before the update.
It was all working correctly before the latest patch on the nvidia gfx card drivers.
Stream as good no stutter, recording was hd and clear....
When i noticed that it wasnt working properly i looked to roll back the driver.... at which point i totally removed the graphics driver by mistake, so after putting it back i whent back to a previous version of the driver (the one i had before)
Issue was still there so i upgraded back to the most recent driver and all programs and software was working (*BONUS)
At which point i again tested the obs out bare in mind the issue im getting is related to BO2 on xbox 360 with aver media capture card sourced into the obs :-)
I have it setup so that obs record does the nvenc and has all the overlays nad every thing
obs stream only has the input from the obs projector...
so i figured out there was an issue only with the cap card, i checked the settings to find out that it had reset to 60fps so i changed it to 30 and problems seemed to be solved.
the xbox will now record the gameplay and stream it and its pretty much bug free
someitmes it will stutter on the stream or even on the projector window on my 2nd monitor (any advice what may cause this)
but now when im trying to do pc i am having a major issue that the window capture for the projector is grabbing any thing that is above it...
i have scoured the internet and found lots of stuff about having aero enabled....
it is not turned off in any of of my obs settings or sources this did work before the gfx card update though....
i have run the windows test and it doesnt come back with any known issues it simply says it couldnt find a solution...
so now i am at a standpoint as i cant record the pc gaming...
so i looked at dxtory i already had it from a while ago so set it up again and it caused major frame drop in csgo
but since i cant actually stream the projector window now im a bit s*it out of luck.
please any advice on what i need to do to fix the issue in a whole so that i can use the projector method for pc and console please would be appreciated.
also all the videos that are outputted now from the obs nvenc one wont play in wmp and no preview will show of the video is this normal>?
thanks in advance
So
thanks in advance
