Question / Help Need help setting up OBS for streaming wow!
EclipseNAR20
currently i have tried to follow every guide out there and even my gf can get it to work on her comp. every time i select scene and source and click preview stream or start it i just have a simple black screen. when i check on twitch just a black screen. can anyone help with this problem and or hop in skype and walk me through this i use to use xsplit and friends telling me to get obs but can't get it to work.
sk3ezer
If you want a quick fix just add a software capture as a source and pick the monitor you are streaming World of Warcraft. This is not the optimal solution but it should work.
sk3ezer
Try changing World of Warcraft from Full Screen, Windowed, and Windowed(Full-screen) and check if that works.
EclipseNAR20
that also does nothing when u set up your source and scene is there anything specific i need ot do ?
it all shows up under game capture just when i click the stream or preview stream doesnt show wow jsut black
sk3ezer
(viewtopic.php?f=5&t=97) Also make sure that you only have the software capture checked in your scene because I also tried to use game capture with WoW but it does not work and shows a black screen.
Edit: I just switched to 32 bit WoW and that works so try that as well.
EclipseNAR20
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5 CPU U 520 @ 1.07GHz
CPU Speed: 1064MHz
Physical Memory: 3893MB Total, 875MB Free
stepping id: 2, model 5, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
monitor 1: pos={0, 0}, size={1366, 768}
Windows Version: 6.1 Build 7600
Aero is Enabled
Adapter 1
Video Adapter: Intel(R) HD Graphics
Video Adapter Dedicated Video Memory: 67108864
Video Adapter Shared System Memory: 1711276032
Adapter 2
Video Adapter: NVIDIA GeForce GT 335M
Video Adapter Dedicated Video Memory: 1034289152
Video Adapter Shared System Memory: 1773068288
Base resolution: 1366x768
Output resolution: 1364x768
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 128
Using graphics capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264: profile High, level 3.2
Video Encoding: x264
fps: 30
width: 1364, height: 768
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Server selection: rtmp://live-iad.justin.tv/app
Total frames rendered: 96, number of frames that lagged: 1 (1.04%) (it's okay for some frames to lag)
RTMPPublisher::SocketLoop: Aborting due to loop exit
x264: frame I:1 Avg QP:11.00 size: 1028
x264: frame P:15 Avg QP:11.67 size: 44
x264: frame B:42 Avg QP:14.67 size: 41
x264: consecutive B-frames: 1.6% 0.0% 0.0% 98.4%
x264: mb I I16..4: 100.0% 0.0% 0.0%
x264: mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.0% 0.0% 0.0% 0.0% 0.0% skip:100.0%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct: 0.0% skip:100.0%
x264: 8x8 transform intra:0.0%
x264: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 98% 0% 2% 0%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 0% 0% 100% 0% 0% 0% 0% 0% 0%
x264: i8c dc,h,v,p: 100% 0% 0% 0%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: kb/s:14.04
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
bufferTime: 2186, outputRateWindowTime: 1000, dropThreshold: 2686
Total frames rendered: 589, number of frames that lagged: 1 (0.17%) (it's okay for some frames to lag)
x264: frame I:3 Avg QP: 9.00 size: 531
x264: frame P:139 Avg QP:11.64 size: 44
x264: frame B:409 Avg QP:14.67 size: 41
x264: consecutive B-frames: 0.9% 0.0% 0.0% 99.1%
x264: kb/s:10.59
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 2182, number of frames that lagged: 4 (0.18%) (it's okay for some frames to lag)
x264: frame I:9 Avg QP: 8.33 size: 365
x264: frame P:540 Avg QP:11.61 size: 44
x264: frame B:1595 Avg QP:14.66 size: 41
x264: consecutive B-frames: 0.8% 0.0% 0.0% 99.2%
x264: kb/s:10.26
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 202, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame P:41 Avg QP:11.66 size: 44
x264: frame B:122 Avg QP:14.66 size: 41
x264: consecutive B-frames: 0.6% 0.0% 0.0% 99.4%
x264: kb/s:11.40
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
bufferTime: 2470, outputRateWindowTime: 1000, dropThreshold: 2970
Total frames rendered: 135, number of frames that lagged: 1 (0.74%) (it's okay for some frames to lag)
x264: frame P:24 Avg QP:11.67 size: 44
x264: frame B:72 Avg QP:14.67 size: 41
x264: consecutive B-frames: 1.0% 0.0% 0.0% 99.0%
x264: kb/s:12.39
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 34, number of frames that lagged: 1 (2.94%) (it's okay for some frames to lag)
Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 74, number of frames that lagged: 1 (1.35%) (it's okay for some frames to lag)
x264: frame P:9 Avg QP:11.67 size: 44
x264: frame B:26 Avg QP:14.65 size: 41
x264: consecutive B-frames: 2.7% 0.0% 0.0% 97.3%
x264: kb/s:16.54
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 62, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame P:6 Avg QP:11.50 size: 44
x264: frame B:17 Avg QP:14.65 size: 41
x264: consecutive B-frames: 4.0% 0.0% 0.0% 96.0%
x264: kb/s:19.71
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 112, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame P:19 Avg QP:11.68 size: 44
x264: frame B:54 Avg QP:14.67 size: 41
x264: consecutive B-frames: 1.3% 0.0% 0.0% 98.7%
x264: kb/s:13.15
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Warning -- D3D10Texture::CreateGDITexture: CreateTexture2D failed, result = 0x8007000E
Using Window Capture
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Warning -- Failed to get DC from capture surface
bufferTime: 2023, outputRateWindowTime: 1000, dropThreshold: 2523
Total frames rendered: 787, number of frames that lagged: 1 (0.13%) (it's okay for some frames to lag)
x264: frame P:188 Avg QP:11.61 size: 44
x264: frame B:558 Avg QP:14.67 size: 41
x264: consecutive B-frames: 0.7% 0.0% 0.0% 99.3%
x264: kb/s:10.42
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 78, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame P:10 Avg QP:11.50 size: 44
x264: frame B:29 Avg QP:14.66 size: 41
x264: consecutive B-frames: 2.4% 0.0% 0.0% 97.6%
x264: kb/s:15.86
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 6, number of frames that lagged: 1 (16.67%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 66, number of frames that lagged: 1 (1.52%) (it's okay for some frames to lag)
x264: frame P:7 Avg QP:11.71 size: 44
x264: frame B:20 Avg QP:14.65 size: 41
x264: consecutive B-frames: 3.4% 0.0% 0.0% 96.6%
x264: kb/s:18.41
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using Monitor Capture
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
bufferTime: 2751, outputRateWindowTime: 1000, dropThreshold: 3251
Total frames rendered: 16458, number of frames that lagged: 367 (2.23%) (it's okay for some frames to lag)
x264: frame I:66 Avg QP: 8.14 size: 293
x264: frame P:4138 Avg QP:11.12 size: 44
x264: frame B:12217 Avg QP:14.55 size: 41
x264: kb/s:9.61
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 31, number of frames that lagged: 1 (3.23%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 273, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame P:59 Avg QP:11.58 size: 44
x264: frame B:175 Avg QP:14.66 size: 41
x264: consecutive B-frames: 0.4% 0.0% 0.0% 99.6%
x264: kb/s:10.94
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
bufferTime: 2099, outputRateWindowTime: 1000, dropThreshold: 2599
Total frames rendered: 1447, number of frames that lagged: 32 (2.21%) (it's okay for some frames to lag)
x264: frame I:6 Avg QP: 8.50 size: 406
x264: frame P:355 Avg QP:11.34 size: 44
x264: frame B:1048 Avg QP:14.57 size: 41
x264: kb/s:9.84
Profiler results:
frame - [100%] [avg time: 11.769 ms] [avg calls per frame: 1] [children: 93%] [unaccounted: 6.98%]
| scene->Preprocess - [0.0595%] [avg time: 0.007 ms] [avg calls per frame: 0]
| video encoding and uploading - [93%] [avg time: 10.94 ms] [avg calls per frame: 1] [children: 51.9%] [unaccounted: 41%]
| | CopyResource - [3.05%] [avg time: 0.359 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [2.74%] [avg time: 0.322 ms] [avg calls per frame: 0]
| | call to encoder - [45.8%] [avg time: 5.396 ms] [avg calls per frame: 0]
| | sending stuff out - [0.289%] [avg time: 0.034 ms] [avg calls per frame: 0]
sk3ezer
Like I edited to my post before, try switching over to 32 bit WoW, pick WoW in the game capture source and see if that works because that just worked for me. Make sure that you're game capture is the only source selected.
sk3ezer
Does monitor capture work when your doing regular things?(Does it work to display your background and windows?)
sk3ezer
I think someone with higher knowledge will have to help you out. You seem to have a problem streaming overall.
sk3ezer
I think you just have a setting wrong that might be screwing everything up, go into your settings and make sure everything looks right.
sk3ezer
I just tried it as well with a black screen, make sure you have it as the only source checked, make the color white, and make the font a reasonable size. Hit Edit Scene and see if the red box comes up to move the text if everything else does not work. Just making you do this to make sure as a last ditch effort.
