Susanoo
If the log file upload didn't work, here is the link to the log on pastebin: http://pastebin.com/Nz7TkBSy
i dont really understand your setup...
because the resolution is more than just way too high for that kind of weak cpu and you are also running a capture card so assume you are using your notebook as a streaming machine while playing on your desktop?
