Minecraft recording problem
zayed_Q7
theres a glitch when i try to record minecraft it doesnt show even if you use the obs way to fix it the gpu thing it still wont work? i found the solution its you just have to open obs as administrator then try recording minecraft now instead of the black screen you keep getting while recording it will actualy record minecraft
