Question / Help Minecraft OBS problems
wookiefever
Hello there,
I am not sure where my problem lies. I am trying to stream minecraft and even sometimes Feed the Beast but I m unable to. When I stream minecraft the stream gets laggy whenever I am fighting mobs. As for Feed the Beast I am unable to stream at all because it is a lag party.
I am using I5-4670K
Asus Z87-Plus
GTX 760
8GB Ram
I have 93.4 Mgps upload and download.
I have lowered by FPS to 30 and I have put the max bitrate at 2500. I am wondering if anyone has some suggestions out there or is my computer causing me problems somewhere?
Thanks,
wookiefever
Hello there,
I am using I5-4670K
Asus Z87-Plus
GTX 760
8GB Ram
Thanks,
wookiefever
Post your log file from the help menu, copy the link here. I would first attempt to disable the preview window from OBS. right click on the preview window, click preview then uncheck "enable view". As for the rest of advice, I will give ti once I see the log :)
Okay thanks dping, I am at working right now so I am unable to post a log but I will post in about 3 hours when I get home
Audio timestamp for device 'Logitech HD Pro Webcam C920' was behind target timestamp by 80
The log is filled to the brim with this line.. Out of curiosity, you don't have that Force audio to use desktop timestamp thing checked under the Advanced tab in settings do you?
EDIT: also check and see if the webcam mic has been muted
thanks for the reply TehGuyz, I do not have that setting checked. Also I am not using the webcam for my mic. I have selected my Blue Snowball as the microphone so I am not sure why it is saying that about the webcam.
