Question / Help Microphone Noise Gate is not working
TJB
I had my mic set-up perfectly. I updated OBS to version v0.638b and downloaded the plugins with it. After a few days of using OBS with the updates, it was working as usual. Today, my microphone is picking up every sound and the noise gate is doing nothing even though it is enabled and I have not changed anything from when it was working! If someone could help me, I'd be very thankful.
how should we help you? if its enabled try to configure it again by changing the sliders maybe some applications changed mic sensitivity or even the mic gain
I did not download any additional application other than the most recent update to OBS. It's just irritating because I have tried to reconfigure my settings, and my mic is either too quiet, or it picks up everything.
I also noticed that when my mic is quiet and there is no background noise going on, the green bar in the threshold preview is bouncing slightly. I'm still stuck and do not know what to do.
Haha! I have posted to the OBS support forums 3 times before this and I have figured it out myself every time.
I just reverted back to the previous version of OBS and it works perfectly. I guess version v0.638b adds some sort of problem to my mic audio settings and the noise gate feature.
