Question / Help Max Payne 2 - God awful FPS lag when streaming with OBS
Exact same thing. This seems to be the exact same issue from the old OBS.
15:02:10.769: CPU Name: Intel(R) Xeon(R) CPU E5-1650 0 @ 3.20GHz
15:02:10.769: CPU Speed: 3200MHz
15:02:10.769: Physical Cores: 6, Logical Cores: 12
15:02:10.769: Physical Memory: 16298MB Total, 13367MB Free
15:02:10.769: Windows Version: 6.1 Build 7601 (revision: 23572; 64-bit)
15:02:10.769: Running as administrator: true
15:02:10.769: Aero is Disabled
15:02:10.769: Portable mode: false
15:02:10.779: OBS 18.0.1 (64bit, windows)
15:02:10.779: ---------------------------------
15:02:10.779: audio settings reset:
15:02:10.779: samples per sec: 48000
15:02:10.779: speakers: 2
15:02:10.780: ---------------------------------
15:02:10.780: Initializing D3D11..
15:02:10.780: Available Video Adapters:
15:02:10.781: Adapter 1: NVIDIA GeForce GTX 980
15:02:10.781: Dedicated VRAM: 4204462080
15:02:10.781: Shared VRAM: 3981838336
15:02:10.781: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:02:10.781: output 2: pos={1920, 0}, size={1440, 900}, attached=true
15:02:10.782: Loading up D3D11 on adapter NVIDIA GeForce GTX 980 (0)
15:02:10.793: D3D11 loaded sucessfully, feature level used: 45056
15:02:11.837: ---------------------------------
15:02:11.837: video settings reset:
15:02:11.837: base resolution: 1920x1080
15:02:11.837: output resolution: 1280x720
15:02:11.837: downscale filter: Lanczos
15:02:11.837: fps: 60/1
15:02:11.837: format: NV12
15:02:11.838: Audio monitoring device:
15:02:11.838: name: Default
15:02:11.838: id: default
15:02:11.838: ---------------------------------
15:02:11.839: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
15:02:11.840: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
15:02:11.840: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
15:02:11.849: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
15:02:11.849: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
15:02:11.849: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
15:02:11.849: Failed to load 'en-US' text for module: 'obs-browser.dll'
15:02:11.849: [browser_source: 'Version: 1.29.0']
15:02:11.850: NVENC supported
15:02:11.887: Couldn't find VLC installation, VLC video source disabled
15:02:11.891: No blackmagic support
15:02:11.895: [Media Foundation encoder]: plugin is disabled for performance reasons on Windows versions prior to 8
15:02:11.896: ---------------------------------
15:02:11.896: Loaded Modules:
15:02:11.896: win-wasapi.dll
15:02:11.896: win-mf.dll
15:02:11.896: win-dshow.dll
15:02:11.896: win-decklink.dll
15:02:11.896: win-capture.dll
15:02:11.896: vlc-video.dll
15:02:11.896: text-freetype2.dll
15:02:11.896: rtmp-services.dll
15:02:11.896: obs-x264.dll
15:02:11.896: obs-vst.dll
15:02:11.896: obs-transitions.dll
15:02:11.896: obs-text.dll
15:02:11.896: obs-qsv11.dll
15:02:11.896: obs-outputs.dll
15:02:11.896: obs-filters.dll
15:02:11.896: obs-ffmpeg.dll
15:02:11.896: obs-browser.dll
15:02:11.896: image-source.dll
15:02:11.896: frontend-tools.dll
15:02:11.896: enc-amf.dll
15:02:11.896: coreaudio-encoder.dll
15:02:11.896: ==== Startup complete ===============================================
15:02:11.897: All scene data cleared
15:02:11.897: ------------------------------------------------
15:02:11.909: WASAPI: Device 'Speakers (High Definition Audio Device)' initialized
15:02:11.917: WASAPI: Device 'Microphone (High Definition Audio Device)' initialized
15:02:11.935: ---------------------------------
15:02:11.935: [DShow Device: 'Video Capture Device'] settings updated:
15:02:11.935: video device: AVerMedia HD Capture C985 Bus 3
15:02:11.935: video path: \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&107a8ef5&0&0018#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a}
15:02:11.935: resolution: 1280x720
15:02:11.935: fps: 60.00 (interval: 166666)
15:02:11.935: format: YV12
15:02:11.936: using video device audio: yes
15:02:11.936: sample rate: 48000
15:02:11.936: channels: 2
15:02:11.936: audio type: Capture
15:02:11.949: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds
15:02:12.076: Switched to scene 'Scene'
15:02:12.076: ------------------------------------------------
15:02:12.076: Loaded scenes:
15:02:12.076: - scene 'Scene':
15:02:12.076: - source: 'Video Capture Device' (dshow_input)
15:02:12.076: - filter: 'Color Correction' (color_filter)
15:02:12.076: - source: 'Game Capture' (game_capture)
15:02:12.076: - source: 'Display Capture' (monitor_capture)
15:02:12.076: - source: 'Webcam' (dshow_input)
15:02:12.076: - source: 'Chat' (browser_source)
15:02:12.076: - source: 'Donor' (browser_source)
15:02:12.076: - source: 'Goal' (browser_source)
15:02:12.076: - source: 'Follower' (browser_source)
15:02:12.076: - scene 'Scene 2':
15:02:12.477: ---------------------------------
15:02:12.478: [DShow Device: 'Webcam'] settings updated:
15:02:12.478: video device: USB Video Device
15:02:12.478: video path: \\?\usb#vid_046d&pid_0825&mi_00#7&e3d04dd&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
15:02:12.478: resolution: 1280x720
15:02:12.478: fps: 30.00 (interval: 333333)
15:02:12.478: format: MJPEG
15:02:12.478: DShow: HDevice::ConnectPins: failed to connect pins (0x80040207): The owner SID on a per-user subscription doesn't exist
15:02:12.478:
15:02:25.049: User added scene 'Scene 3'
15:02:25.050: User switched to scene 'Scene 3'
15:02:32.196: User added source 'Game Capture' (game_capture) to scene 'Scene 3'
15:02:39.255: [game-capture: 'Game Capture'] attempting to hook fullscreen process: maxpayne2.exe
15:02:39.256: [game-capture: 'Game Capture'] using helper (direct hook)
15:02:39.256: [game-capture: 'Game Capture'] hook not loaded yet, retrying..
15:02:43.272: [game-capture: 'Game Capture'] attempting to hook fullscreen process: maxpayne2.exe
15:02:43.285: [game-capture: 'Game Capture'] d3d8 memory capture successfull
15:02:43.290: [game-capture: 'Game Capture'] memory capture successful
15:03:31.614: [game-capture: 'Game Capture'] capture window no longer exists, terminating capture
15:03:31.615: [game-capture: 'Game Capture'] capture stopped
15:04:10.169: ==== Shutting down ==================================================
15:04:10.171: Switched to scene '(null)'
15:04:11.208: WASAPI: Device 'Speakers (High Definition Audio Device)' Terminated
15:04:11.209: WASAPI: Device 'Microphone (High Definition Audio Device)' Terminated
15:04:11.211: All scene data cleared
15:04:11.211: ------------------------------------------------
15:04:11.226: Freeing OBS context data
15:04:11.281: == Profiler Results =============================
15:04:11.281: run_program_init: 1338.27 ms
15:04:11.281: ┣OBSApp::AppInit: 1.015 ms
15:04:11.281: ┃ ┗OBSApp::InitLocale: 0.647 ms
15:04:11.281: ┗OBSApp::OBSInit: 1333.92 ms
15:04:11.281: ┣obs_startup: 0.55 ms
15:04:11.281: ┗OBSBasic::OBSInit: 1315.95 ms
15:04:11.281: ┣OBSBasic::InitBasicConfig: 0.203 ms
15:04:11.281: ┣OBSBasic::ResetAudio: 0.109 ms
15:04:11.281: ┣OBSBasic::ResetVideo: 1059.79 ms
15:04:11.281: ┣OBSBasic::InitOBSCallbacks: 0.003 ms
15:04:11.281: ┣OBSBasic::InitHotkeys: 0.03 ms
15:04:11.281: ┣obs_load_all_modules: 56.859 ms
15:04:11.281: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.175 ms
15:04:11.281: ┃ ┣obs_init_module(enc-amf.dll): 0.106 ms
15:04:11.281: ┃ ┣obs_init_module(frontend-tools.dll): 1.304 ms
15:04:11.281: ┃ ┣obs_init_module(image-source.dll): 0.003 ms
15:04:11.281: ┃ ┣obs_init_module(obs-browser.dll): 0.043 ms
15:04:11.281: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.343 ms
15:04:11.281: ┃ ┣obs_init_module(obs-filters.dll): 0.007 ms
15:04:11.281: ┃ ┣obs_init_module(obs-outputs.dll): 0.004 ms
15:04:11.281: ┃ ┣obs_init_module(obs-qsv11.dll): 34.267 ms
15:04:11.281: ┃ ┣obs_init_module(obs-text.dll): 0.206 ms
15:04:11.281: ┃ ┣obs_init_module(obs-transitions.dll): 0.003 ms
15:04:11.281: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
15:04:11.281: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
15:04:11.281: ┃ ┣obs_init_module(rtmp-services.dll): 0.213 ms
15:04:11.281: ┃ ┣obs_init_module(text-freetype2.dll): 0.021 ms
15:04:11.281: ┃ ┣obs_init_module(vlc-video.dll): 0.022 ms
15:04:11.281: ┃ ┣obs_init_module(win-capture.dll): 0.038 ms
15:04:11.281: ┃ ┣obs_init_module(win-decklink.dll): 3.58 ms
15:04:11.281: ┃ ┣obs_init_module(win-dshow.dll): 2.42 ms
15:04:11.281: ┃ ┣obs_init_module(win-mf.dll): 0.552 ms
15:04:11.281: ┃ ┣obs_init_module(win-wasapi.dll): 0.003 ms
15:04:11.281: ┃ ┗reset_win32_symbol_paths: 0.076 ms
15:04:11.281: ┣OBSBasic::ResetOutputs: 0.285 ms
15:04:11.281: ┣OBSBasic::CreateHotkeys: 0.154 ms
15:04:11.281: ┣OBSBasic::InitService: 0.057 ms
15:04:11.281: ┣OBSBasic::InitPrimitives: 0.226 ms
15:04:11.281: ┗OBSBasic::Load: 179.468 ms
15:04:11.281: obs_hotkey_thread(25 ms): min=0.001 ms, median=0.003 ms, max=65.524 ms, 99th percentile=0.052 ms, 99.9789% below 25 ms
15:04:11.281: audio_thread(Audio): min=0 ms, median=0.039 ms, max=4.07 ms, 99th percentile=0.071 ms
15:04:11.281: obs_video_thread(16.6667 ms): min=0.216 ms, median=0.595 ms, max=146.996 ms, 99th percentile=2.21 ms, 99.9581% below 16.667 ms
15:04:11.281: ┣tick_sources: min=0.001 ms, median=0.01 ms, max=146.083 ms, 99th percentile=1.603 ms
15:04:11.281: ┣render_displays: min=0.001 ms, median=0.244 ms, max=15.26 ms, 99th percentile=0.396 ms
15:04:11.281: ┗output_frame: min=0.205 ms, median=0.271 ms, max=1.629 ms, 99th percentile=0.441 ms
15:04:11.281: ┣gs_context(video->graphics): min=0.057 ms, median=0.088 ms, max=1.456 ms, 99th percentile=0.139 ms
15:04:11.281: ┃ ┣render_video: min=0.016 ms, median=0.027 ms, max=0.217 ms, 99th percentile=0.044 ms
15:04:11.281: ┃ ┃ ┣render_main_texture: min=0.003 ms, median=0.009 ms, max=0.178 ms, 99th percentile=0.022 ms
15:04:11.281: ┃ ┃ ┣render_output_texture: min=0.002 ms, median=0.007 ms, max=0.083 ms, 99th percentile=0.017 ms
15:04:11.281: ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.007 ms, max=0.025 ms, 99th percentile=0.01 ms
15:04:11.281: ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.002 ms, max=0.009 ms, 99th percentile=0.004 ms
15:04:11.281: ┃ ┣download_frame: min=0 ms, median=0.002 ms, max=0.369 ms, 99th percentile=0.003 ms
15:04:11.281: ┃ ┗gs_flush: min=0.036 ms, median=0.058 ms, max=1.415 ms, 99th percentile=0.091 ms
15:04:11.281: ┗output_video_data: min=0.136 ms, median=0.181 ms, max=0.833 ms, 99th percentile=0.317 ms
15:04:11.281: video_thread(video): min=0 ms, median=0 ms, max=0.031 ms, 99th percentile=0.001 ms
15:04:11.281: =================================================
15:04:11.281: == Profiler Time Between Calls ==================
15:04:11.281: obs_hotkey_thread(25 ms): min=24.56 ms, median=25.39 ms, max=90.821 ms, 99.8312% within ±2% of 25 ms (0% lower, 0.168776% higher)
15:04:11.281: obs_video_thread(16.6667 ms): min=7.737 ms, median=16.667 ms, max=147.002 ms, 99.9161% within ±2% of 16.667 ms (0.0419522% lower, 0.0419522% higher)
15:04:11.291: Number of memory leaks: 33
multi-adapter is still turned on.
Display capture is still in the scene.
I added a new scene and added just the display capture, do I actually have to remove them all together? Just checked my settings from 2 scenes and both have multi-adapter disabled.
Edit: deleted all my scenes and started from scratch with just game capture, multi-adapter disabled and it's still happening. I'll leave Max Payne 2 until OBS Studio is updated or there's a fix for Max Payne 2. If anyone has the game and OBS Studio then please give it a shot, it could just be me.
I'm having the same problem with Max Payne 1 and the low FPS issue. As soon as I open OBS studio (and not even attempt to stream or record) the FPS in Max Payne drops to like the 10fps range.
Huh... what the heck.... I went to attempt it again to show my log.... and it works perfectly now.... haha. I'll drop it anyways
23:44:24.605: CPU Name: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
23:44:24.605: CPU Speed: 3400MHz
23:44:24.605: Physical Cores: 4, Logical Cores: 4
23:44:24.605: Physical Memory: 16313MB Total, 12332MB Free
23:44:24.605: Windows Version: 10.0 Build 14393 (revision: 953; 64-bit)
23:44:24.605: Running as administrator: true
23:44:24.605: Aero is Enabled (Aero is always on for windows 8 and above)
23:44:24.605: Portable mode: false
23:44:24.612: OBS 18.0.1 (64bit, windows)
23:44:24.612: ---------------------------------
23:44:24.613: ---------------------------------
23:44:24.613: audio settings reset:
23:44:24.613: samples per sec: 44100
23:44:24.613: speakers: 2
23:44:24.614: ---------------------------------
23:44:24.614: Initializing D3D11..
23:44:24.614: Available Video Adapters:
23:44:24.615: Adapter 1: NVIDIA GeForce GTX 980 Ti
23:44:24.615: Dedicated VRAM: 2104164352
23:44:24.615: Shared VRAM: 4257951744
23:44:24.615: output 1: pos={0, 0}, size={1920, 1080}, attached=true
23:44:24.615: output 2: pos={1920, 0}, size={1920, 1080}, attached=true
23:44:24.617: Loading up D3D11 on adapter NVIDIA GeForce GTX 980 Ti (0)
23:44:24.631: D3D11 loaded sucessfully, feature level used: 45056
23:44:25.250: ---------------------------------
23:44:25.250: video settings reset:
23:44:25.250: base resolution: 1920x1080
23:44:25.250: output resolution: 1280x720
23:44:25.250: downscale filter: Lanczos
23:44:25.250: fps: 60/1
23:44:25.250: format: NV12
23:44:25.251: Audio monitoring device:
23:44:25.251: name: Default
23:44:25.251: id: default
23:44:25.251: ---------------------------------
23:44:25.253: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
23:44:25.256: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
23:44:25.260: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
23:44:25.271: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
23:44:25.272: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
23:44:25.272: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
23:44:25.273: Failed to load 'en-US' text for module: 'obs-browser.dll'
23:44:25.273: [browser_source: 'Version: 1.29.0']
23:44:25.281: NVENC supported
23:44:25.323: Couldn't find VLC installation, VLC video source disabled
23:44:25.327: No blackmagic support
23:44:25.353: ---------------------------------
23:44:25.353: Loaded Modules:
23:44:25.353: win-wasapi.dll
23:44:25.353: win-mf.dll
23:44:25.353: win-dshow.dll
23:44:25.353: win-decklink.dll
23:44:25.353: win-capture.dll
23:44:25.353: vlc-video.dll
23:44:25.353: text-freetype2.dll
23:44:25.353: rtmp-services.dll
23:44:25.353: obs-x264.dll
23:44:25.353: obs-vst.dll
23:44:25.353: obs-transitions.dll
23:44:25.353: obs-text.dll
23:44:25.353: obs-qsv11.dll
23:44:25.353: obs-outputs.dll
23:44:25.353: obs-filters.dll
23:44:25.353: obs-ffmpeg.dll
23:44:25.353: obs-browser.dll
23:44:25.353: image-source.dll
23:44:25.353: frontend-tools.dll
23:44:25.353: enc-amf.dll
23:44:25.353: coreaudio-encoder.dll
23:44:25.353: ==== Startup complete ===============================================
23:44:25.360: All scene data cleared
23:44:25.360: ------------------------------------------------
23:44:25.377: WASAPI: Device 'LG TV-4 (NVIDIA High Definition Audio)' initialized
23:44:25.377: source 'Desktop Audio' enabled push-to-mute
23:44:25.386: WASAPI: Device 'Microphone (Yeti Stereo Microphone)' initialized
23:44:25.386: source 'Mic/Aux' enabled push-to-mute
23:44:25.441: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
23:44:26.456: ---------------------------------
23:44:26.456: [DShow Device: 'webcamforbox'] settings updated:
23:44:26.456: video device: Logitech HD Webcam C615
23:44:26.456: video path: \\?\usb#vid_046d&pid_082c&mi_02#6&d2cb4d2&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
23:44:26.456: resolution: 1280x720
23:44:26.456: fps: 30.00 (interval: 333333)
23:44:26.456: format: I420
23:44:26.536: warning: deprecated pixel format used, make sure you did set range correctly
23:44:26.578: Switched to scene 'rockdad'
23:44:26.580: ------------------------------------------------
23:44:26.580: Loaded scenes:
23:44:26.580: - scene 'RETROELGATO':
23:44:26.580: - source: 'bgbox' (image_source)
23:44:26.580: - source: 'drawful2' (game_capture)
23:44:26.580: - source: 'MSC' (game_capture)
23:44:26.580: - source: 'fo4' (game_capture)
23:44:26.580: - source: 'mgsback' (image_source)
23:44:26.580: - filter: 'Color Correction' (color_filter)
23:44:26.580: - source: 'cambox' (image_source)
23:44:26.580: - source: 'webcamforbox' (dshow_input)
23:44:26.580: - source: 'beard' (image_source)
23:44:26.580: - source: 'crazeyawesomename' (image_source)
23:44:26.580: - source: 'BRB short break' (text_gdiplus)
23:44:26.580: - scene 'rockdad':
23:44:26.580: - source: 'maxpayne1' (window_capture)
23:44:26.580: - source: 'skyruim' (game_capture)
23:44:26.580: - source: 'southpawk' (game_capture)
23:44:26.580: - source: 'SWTOR' (game_capture)
23:44:26.580: - source: 'codgho' (game_capture)
23:44:26.580: - source: 'codaw' (game_capture)
23:44:26.580: - source: 'spase' (game_capture)
23:44:26.580: - source: 'Game Capture' (game_capture)
23:44:26.580: - source: 'draw' (window_capture)
23:44:26.580: - source: 'rocksmith' (window_capture)
23:44:26.580: - scene 'GB':
23:44:26.580: - source: 'gbbg' (image_source)
23:44:26.580: - source: 'Window Capture' (window_capture)
23:44:26.580: - filter: 'Crop/Pad' (crop_filter)
23:44:26.580: - source: 'gbbb' (window_capture)
23:44:26.580: - source: 'gb' (game_capture)
23:44:26.580: - source: 'starting shortly' (text_gdiplus)
23:44:26.580: - scene 'n64':
23:44:26.580: - source: 'n64bg' (image_source)
23:44:26.580: - source: 'n64p64' (window_capture)
23:44:26.580: - scene 'SNES':
23:44:26.580: - source: 'snes bg' (image_source)
23:44:26.580: - source: 'snes9x' (window_capture)
23:44:26.580: - source: 'Game Capture snes' (game_capture)
23:44:26.580: - source: 'Window Capture 2' (window_capture)
23:44:26.580: - scene 'division':
23:44:26.580: - scene 'NES':
23:44:26.580: - source: 'NESBG' (image_source)
23:44:26.580: - source: 'live' (window_capture)
23:44:26.580: - source: 'nesemu' (window_capture)
23:44:26.580: - scene 'kirby':
23:44:26.580: - source: 'kirbybg' (image_source)
23:44:26.580: - source: 'vba' (window_capture)
23:44:26.580: - source: 'kirbgif1' (image_source)
23:44:26.580: - source: 'awgif' (image_source)
23:44:26.580: - source: 'bshipaw' (image_source)
23:44:26.580: - source: 'kibyrun' (image_source)
23:44:26.580: - source: 'lapras' (image_source)
23:44:26.580: - scene 'nocam':
23:44:26.580: - scene 'ElgatoHD30':
23:44:26.580: - scene 'marathon':
23:44:26.580: - scene 'ps1':
23:44:26.580: - source: 'ps1bg' (image_source)
23:44:26.580: - source: 'Game Capture 1' (game_capture)
23:44:26.580: - source: 'ps222' (game_capture)
23:44:26.580: - scene 'elgatomadden':
23:44:26.580: - source: 'egloo' (dshow_input)
23:44:26.580: - filter: 'Video Delay (Async)' (async_delay_filter)
23:44:26.580: - scene 'recording':
23:44:26.580: - scene 'daypay':
23:44:26.580: - source: 'payday' (game_capture)
23:44:28.925: ---------------------------------
23:44:28.925: [DShow Device: 'egloo'] settings updated:
23:44:28.925: video device: Elgato Game Capture HD
23:44:28.925: video path: __elgato
23:44:28.925: resolution: 1920x1080
23:44:28.925: fps: 60.00 (interval: 166666)
23:44:28.925: format: UYVY
23:44:28.925: using video device audio: yes
23:44:28.925: sample rate: 48000
23:44:28.925: channels: 2
23:44:28.925: audio type: Capture
23:44:30.884: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
maybe try window capture? idk. I just tried it 5 minutes ago and it had the same problem and now it doesn't.... I'll try and figure this out and come back
