Question / Help Massive Ping Problems while Stream
previsioN_
Hey guys !
i am a new streamer and i read a lot about encodings and so on and tried to find the best one for me.
my upload ist Upload :: 4.4 Mbps/4.5 Mbps.
My encoding is set on 1300 / buffersize same.
CPU Intel Core i5-2500K Box (4x3,30GHz)
RAM DDR3 G.Skill 8GB
Grafikkarte Geforce GTX 570
Motherboard MB ASUS P8H67-M PRO R.3.0
PROBLEM:
If i go higher i have ms problems and i start lagging.
league of legends ist good quality but cs:go looks just like shit :D
can you guys help me? dont know what to do and how to use my obs settings perfectly so can you give me some tipps?
02:33:28: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
02:33:28: -------------------------------
02:33:28: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
02:33:28: CPU Speed: 3311MHz
02:33:28: Physical Memory: 4095MB Total, 4095MB Free
02:33:28: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
02:33:28: monitor 1: pos={0, 0}, size={1920, 1080}
02:33:28: Windows Version: 6.1 Build 7601 S
02:33:28: Aero is Enabled
02:33:28: OBS Modules:
02:33:28: Base Address Module
02:33:28: 010F0000 OBS.exe
02:33:28: 50810000 OBSApi.dll
02:33:28: 56590000 CLRHostPlugin.dll
02:33:28: 505E0000 DShowPlugin.dll
02:33:28: 505B0000 GraphicsCapture.dll
02:33:28: 50080000 NoiseGate.dll
02:33:28: 50590000 PSVPlugin.dll
02:33:28: 554D0000 scenesw.dll
02:33:28: ------------------------------------------
02:33:28: Adapter 1
02:33:28: Video Adapter: NVIDIA GeForce GTX 570
02:33:28: Video Adapter Dedicated Video Memory: 1294401536
02:33:28: Video Adapter Shared System Memory: 2952671232
02:33:28: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
02:33:28: Using fixed low latency mode, factor 20
02:33:28: =====Stream Start: 2015-05-14, 02:33:28===============================================
02:33:28: Multithreaded optimizations: On
02:33:28: Base resolution: 1920x1080
02:33:28: Output resolution: 1920x1080
02:33:28: Loading up D3D10 on NVIDIA GeForce GTX 570 (Adapter 1)...
02:33:28: Audio Format: 44100 Hz
02:33:28: Audio Channels: 2 Ch
02:33:28: Playback device {0.0.0.00000000}.{6957555a-f64d-464c-b19d-d8e3842dda8b}
02:33:28: Using desktop audio input: Lautsprecher (2- Sennheiser 3D G4ME1)
02:33:28: Global Audio time adjust: 0
02:33:28: Using 7.1 surround speaker setup
02:33:28: Using auxilary audio input: Mikrofon (2- Sennheiser 3D G4ME1)
02:33:28: Mic time offset: 0
02:33:28: Audio Encoding: AAC
02:33:28: bitrate: 128
02:33:28: Using graphics capture
02:33:28: Trying to hook process: csgo.exe
02:33:28: Scene buffering time set to 400
02:33:28: Video Encoding: x264
02:33:28: fps: 30
02:33:28: width: 1920, height: 1080
02:33:28: preset: veryfast
02:33:28: profile: main
02:33:28: keyint: 60
02:33:28: CBR: yes
02:33:28: CFR: yes
02:33:28: max bitrate: 1300
02:33:28: buffer size: 1300
ps: i read to disable my "aero" but what is it and how can i disable it? :D
dont disable aero. increase scene buffering to 700ms and enable minimize network impact, which is the setting that should fix your issue. Second running 1080p with only 1300 bitrate will look aweful. even 720p that is low, recommendation is to lower your resolution to 540 616 or 720p which will allow you do drop your x264 preset to medium, fast or faster respectively. i.e. 540p medium preset, 616p, fast preset, 720p faster preset.
