Question / Help LGP - Lite + Stream engine woes
  • Thread starter Thread starter Narcfox
  • Start date Start date
N
Narcfox
Okay so I've read maybe 45 articles on this so far, watched about as many youtube videos and I got nothin.
The situation as it stands is, stream engine doesn't show up in OBS, same as every other damn thread. The exception however, is that I have done everything diagnostically I can think of to try and fix this problem. I've been trouble shooting this for days. The check list is so far: Disabled all plugins on OBS, using the x86 (32bit) version of OBS, reinstalled drivers, reinstalled OBS, don't need to worry about skype it isn't installed, nothing boots with my computer except vital drivers, chrome firefox IE and opera are all off and don't boot with my pc.
I've gone through this with a fine tooth comb annnd zip, it still doesn't work. Even worse is that it worked fine less than a few days ago.
Here's the real kicker though, they all work. Rec central works fine, so does OBS, it just wont detect stream engine. The really weird part is it wont detect the right version of the LGP driver either, it detects C8350, but I have the GL310.
Xplit works fine though it isn't using stream engine. I'm stumped, anyone got any help?
What the hell is a stream engine? Where is your log file? What is the source that your LGP Lite is capturing?
Why are you commenting? Like, the problem is with Stream Engine being detected in OBS, if you have no idea what that is why are you here?
Hey so, I just bought the LGP as well, and I was having this trouble as well, and oblivious to me you actually have to download LGP Stream Engine separately, RECentral isnt the proper thing you need for OBS to recognize the capture card. Hope this helps!
You cant have Google Chrome open and it needs to be OBS 32bit, you can use chrome after OBS is running but if it is active before hand, Stream Engine wont be detected or you will get a red screen.
