Giiggsouille
Hello,
I stream poker from Switzerland to twitch with OBS, but the viewers tell me that this lag. Here is my PC configuration:
I stream on 720p, and here's config on OBS:
Will you help me, because I do not know what it comes. Do you think my bandwidth is sufficient?
Or is it a problem with my graphics card? But if that's why at times it works?
Thanks in advance...
- Intel Core i7 920 2.66 GHz CPU
- Graphics card: GTX 260
- RAM: 6 GB
- Internet connection upload: 2.5 MB
- x264
- Use CBR: one
- Quality 8
- Max Bitrate: 1800
- FMS Url: EU London, UK
- Resolution encoding: 720p - 25FPS
