Question / Help Issues With Consistent Frame Drops & Poor Connection
Momonocle
Hey everyone,
New to posting on these forums so bare with me here. Recently had a windows update and since then streaming has been essentially impossible. I can't immediately tell if this is
A. OBS
B. My Computer
C. My ISP/Router
But I have my suspicions it has something to do with the Windows Update conflicting with my Router perhaps.
However, I want to rule out that this is NOT an OBS issue. Posting my log, let me know if any of you can see anything out of the ordinary.
Previous to the update I did an 8hr stream with no dropped frames whatsoever and haven't changed any settings so I WAS able to capably stream at 3000 kbps with no issues. My speeds have also been checked numerous times and I have consistent 300 mbps download and 5 mbps - 10 mbps upload typically. I also did an hour long twitch inspector test and found no immediate help there either, said my setup was fine but there was major spikes consistently happening.
LOG:
15:28:00.617: CPU Name: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
15:28:00.617: CPU Speed: 3592MHz
15:28:00.617: Physical Cores: 4, Logical Cores: 8
15:28:00.617: Physical Memory: 12227MB Total, 7811MB Free
15:28:00.617: Windows Version: 10.0 Build 17763 (revision: 1039; 64-bit)
15:28:00.617: Running as administrator: true
15:28:00.618: Aero is Enabled (Aero is always on for windows 8 and above)
15:28:00.618: Windows 10 Gaming Features:
15:28:00.618: Game Bar: Off
15:28:00.618: Game DVR: Off
15:28:00.618: Game DVR Background Recording: Off
15:28:00.618: Game Mode: Off
15:28:00.620: Sec. Software Status:
15:28:00.621: Avast Antivirus: enabled (AV)
15:28:00.622: Windows Defender Antivirus: disabled (AV)
15:28:00.622: Windows Firewall: enabled (FW)
15:28:00.622: Windows Defender Antivirus: disabled (ASW)
15:28:00.622: Avast Antivirus: enabled (ASW)
15:28:00.623: Current Date/Time: 2020-02-18, 15:28:00
15:28:00.623: Browser Hardware Acceleration: true
15:28:00.623: Portable mode: false
15:28:01.026: OBS 24.0.3 (64-bit, windows)
15:28:01.026: ---------------------------------
15:28:01.027: ---------------------------------
15:28:01.027: audio settings reset:
15:28:01.027: samples per sec: 44100
15:28:01.027: speakers: 2
15:28:01.028: ---------------------------------
15:28:01.028: Initializing D3D11...
15:28:01.028: Available Video Adapters:
15:28:01.030: Adapter 0: NVIDIA GeForce GTX 745
15:28:01.030: Dedicated VRAM: 4250337280
15:28:01.030: Shared VRAM: 2115696640
15:28:01.030: output 0: pos={0, 0}, size={1600, 900}, attached=true
15:28:01.030: output 1: pos={-1600, 0}, size={1600, 900}, attached=true
15:28:01.033: Loading up D3D11 on adapter NVIDIA GeForce GTX 745 (0)
15:28:01.077: D3D11 loaded successfully, feature level used: b000
15:28:01.077: D3D11 GPU priority setup success
15:28:01.501: ---------------------------------
15:28:01.501: video settings reset:
15:28:01.501: base resolution: 1600x900
15:28:01.501: output resolution: 1280x720
15:28:01.501: downscale filter: Bicubic
15:28:01.501: fps: 30/1
15:28:01.501: format: NV12
15:28:01.501: YUV mode: 601/Partial
15:28:01.501: NV12 texture support enabled
15:28:01.503: Audio monitoring device:
15:28:01.503: name: Speakers (Realtek High Definition Audio)
15:28:01.503: id: {0.0.0.00000000}.{a43c78a5-1622-472e-b1b5-644eb6128cb6}
15:28:01.503: ---------------------------------
15:28:01.514: [CoreAudio encoder]: Adding CoreAudio AAC encoder
15:28:01.514: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
15:28:01.560: [AMF] AMF Test failed due to one or more errors.
15:28:01.560: Failed to initialize module 'enc-amf.dll'
15:28:01.585: [obs-browser]: Version 2.7.15
15:28:01.590: NVENC supported
15:28:01.665: VLC found, VLC video source enabled
15:28:01.672: No blackmagic support
15:28:01.678: ---------------------------------
15:28:01.678: Loaded Modules:
15:28:01.678: win-wasapi.dll
15:28:01.678: win-mf.dll
15:28:01.678: win-dshow.dll
15:28:01.678: win-decklink.dll
15:28:01.678: win-capture.dll
15:28:01.678: vlc-video.dll
15:28:01.678: text-freetype2.dll
15:28:01.678: rtmp-services.dll
15:28:01.678: obs-x264.dll
15:28:01.678: obs-vst.dll
15:28:01.678: obs-transitions.dll
15:28:01.678: obs-text.dll
15:28:01.678: obs-qsv11.dll
15:28:01.678: obs-outputs.dll
15:28:01.678: obs-filters.dll
15:28:01.678: obs-ffmpeg.dll
15:28:01.678: obs-browser.dll
15:28:01.678: image-source.dll
15:28:01.678: frontend-tools.dll
15:28:01.678: enc-amf.dll
15:28:01.678: decklink-ouput-ui.dll
15:28:01.678: coreaudio-encoder.dll
15:28:01.678: ==== Startup complete ===============================================
15:28:01.705: All scene data cleared
15:28:01.705: ------------------------------------------------
15:28:01.795: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
15:28:01.835: WASAPI: Device 'Microphone (2- Yeti Stereo Microphone)' initialized
15:28:01.876: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
15:28:01.876:
15:28:02.313: [rtmp-services plugin] Successfully updated file 'services.json' (version 123)
15:28:02.314: [rtmp-services plugin] Successfully updated package (version 123)
3:28:04 PM.575: ------------------------------------------------
3:28:05 PM.873: ---------------------------------
3:28:05 PM.873: [DShow Device: 'Elgato'] settings updated:
3:28:05 PM.873: video device: Elgato Game Capture HD
3:28:05 PM.873: video path: __elgato
3:28:05 PM.873: resolution: 1920x1080
3:28:05 PM.873: fps: 30.00 (interval: 333333)
3:28:05 PM.873: format: UYVY
3:28:05 PM.873: using video device audio: yes
3:28:05 PM.873: sample rate: 48000
3:28:05 PM.873: channels: 2
3:28:05 PM.873: audio type: Capture
3:34:58 PM.674: Settings changed (stream 1)
3:34:58 PM.674: ------------------------------------------------
3:35:01 PM.951: [jim-nvenc: 'streaming_h264'] settings:
3:35:01 PM.951: rate_control: CBR
3:35:01 PM.951: bitrate: 3000
3:35:01 PM.951: cqp: 20
3:35:01 PM.951: keyint: 60
3:35:01 PM.951: preset: hq
3:35:01 PM.951: profile: high
3:35:01 PM.951: width: 1280
3:35:01 PM.951: height: 720
3:35:01 PM.951: 2-pass: false
3:35:01 PM.951: b-frames: 2
3:35:01 PM.951: lookahead: false
3:35:01 PM.951: psycho_aq: true
3:35:01 PM.951:
3:35:01 PM.962: [CoreAudio AAC: 'avc_aac_stream']: settings:
3:35:01 PM.962: mode: AAC
3:35:01 PM.962: bitrate: 160
3:35:01 PM.962: sample rate: 44100
3:35:01 PM.962: cbr: on
3:35:01 PM.962: output buffer: 1536
3:35:01 PM.963: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-ord02.twitch.tv/app...
3:35:02 PM.004: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
3:35:02 PM.887: [rtmp stream: 'adv_stream'] Connection to rtmp://live-ord02.twitch.tv/app successful
3:35:02 PM.892: ==== Streaming Start ===============================================
3:35:38 PM.734: adding 92 milliseconds of audio buffering, total audio buffering is now 139 milliseconds (source: intermission)
3:35:38 PM.734:
3:37:07 PM.496: [rtmp stream: 'adv_stream'] Stream shutdown timeout reached (30 second(s))
3:37:07 PM.496: [rtmp stream: 'adv_stream'] User stopped the stream
3:37:07 PM.496: Output 'adv_stream': stopping
3:37:07 PM.496: Output 'adv_stream': Total frames output: 1325 (3727 attempted)
3:37:07 PM.496: Output 'adv_stream': Total drawn frames: 3766
3:37:07 PM.496: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 2402 (64.4%)
3:37:07 PM.497: [rtmp stream: 'adv_stream'] Freeing 4246 remaining packets
This is: your network card or drivers, your local cabling, your local network/router, or your ISP. OBS cannot tell which.
You can also run TwitchTest to help you choose the best ingest server.
Thanks for the reply
Some things I can rule out are servers as I have already done testing on that previous to this post as you have suggested.
I am going to try to troubleshoot some of those other options...my guess to windows update is it is probably network drivers?
