Question / Help Issue with obs.live high in game fps low fps OBS
#1
Right, so I know this is a recurring issue with a lot of users and I have gone through so many posts to try and solve this issue because I have been streaming for a while and never changed settings and it just suddenly started, unless it means my GPU is dying (I sincerely hope not) I don't know what to do or how to solve this issue,
here is an log report https://obsproject.com/logs/pVqC0Zqwl_s4ZGg_
yes it does seem to be very long I am sorry, I kept on fiddling with settings trying to fix stuff but no luck so I am hoping someone here can help? the thing is I know what the issue in the sense that my GPU is being bottle necked and using so much power but I don't know why it is all of a sudden starting to be an issue
Yes, I have turned on vsync in games and lowered graphical options on my games
I never wanted to make this post but I just am fed up and want some other peoples perspective and something I may not have seen
#3
16:35:40.641: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 666 (7.0%)
16:35:40.642: Video stopped, number of skipped frames due to encoding lag: 706/9455 (7.5%)
You're also getting about as much encoding lag as rendering lag, so maybe your GPU is failing? The Windows update should address your rendering lag, but not your encoding lag issue.
#4
Yeah I did update Windows and turn off game mode, but I'm not sure if that was before or after the logs, i have a feeling it might be my gpu failing (I really hope that isn't the case) not sure if there are actually any ways to tell, but I donwloaded something which turns off my game mode as there actually no disable or enable toggle on my settings
#8
If your logfiles still say this:
14:29:17.062: Windows Version: 10.0 Build 17134 (revision: 766; 64-bit)
Then Windows is out of date. That build is from spring 2018; it is also called version 1803.
Current version is 1903, and the issue with Game Mode degrading OBS performance was addressed in 1809, in October 2018.
https://pureinfotech.com/windows-10-version-release-history/
Ah okay, I did update after this log, the way I did it was click the check for updates button and it updated (didn't take long) but is there a way to download the latest without using the check for update button ?
