Inconsistent sound quality
BobT
Hi. I'm new to OBS. I used a Samson C01U Pro mic with some plugin filters. My video recording uses 3 scenes: webcam; laptop cam; and image slideshow. All three scenes use the same mic with the same settings. I'm getting different sound quality from scene to scene. Shouldn't the sound be the same for each scene because I didn't change anything with the mic settings?
depends on what your computer is doing, if it powerful enough for your settings/what you are asking it to do?
for example, you can have different filters/effects in each scene, causing different hardware resource demands (CPU, GPU, RAM, etc). If system getting overloaded, then all kinds of anomalous behavior possible
the other option is that you have settings which specifically impact audio per scene, or something else entirely... ah, the joy of complex tech
When asking for help, always a good idea for follow forum etiquette as per pinned post in this forum
And for general reference Audio related
