Open Broadcaster Software v0.456a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
CPU Speed: 3200MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 2, model 5, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
Aero is Enabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 560
Video Adapter Dedicated Video Memory: 1025966080
Video Adapter Shared System Memory: 3221372928
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Using auxilary audio input: Microphone (USB Audio Device)
Audio Encoding: MP3
bitrate: 128
Video Encoding: x264
fps: 24
width: 1280, height: 720
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
New Scene
Using Monitor Capture
Total frames rendered: 181, number of frames that lagged: 87 (48.07%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
device: USB Video Device,
device id \\?\usb#vid_046d&pid_081b&mi_00#7&206cb1df&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
chosen type: YUY2, usingFourCC: false, res: 1280x960 - 1280x960, fps: 5-7.5, fourCC: 'YUY2'
Using directshow input
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
Total frames rendered: 5626, number of frames that lagged: 4804 (85.39%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
Using text output
Using text output
Total frames rendered: 11369, number of frames that lagged: 11067 (97.34%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
Using text output
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
Total frames rendered: 19, number of frames that lagged: 19 (100.00%) (it's okay for some frames to lag)
Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
Using text output
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
bufferTime: 2617, outputRateWindowTime: 1000, dropThreshold: 3117
Total frames rendered: 222362, number of frames that lagged: 196894 (88.55%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
Using Window Capture
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
Total frames rendered: 19428, number of frames that lagged: 10688 (55.01%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
bufferTime: 2517, outputRateWindowTime: 1000, dropThreshold: 3017
Total frames rendered: 525722, number of frames that lagged: 403255 (76.70%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
Warning -- DShowPlugin: Invalid device: name 'USB Video Device', path '\\?\usb#vid_046d&pid_081b&mi_00#7&206cb1df&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global'
Warning -- D3D10Texture::CreateTexture: CreateTexture2D failed, result = 0x80070057
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
bufferTime: 2760, outputRateWindowTime: 1000, dropThreshold: 3260
Total frames rendered: 1396, number of frames that lagged: 1300 (93.12%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
bufferTime: 2462, outputRateWindowTime: 1000, dropThreshold: 2962
Total frames rendered: 141, number of frames that lagged: 138 (97.87%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
device: Logitech HD Webcam C310,
device id \\?\usb#vid_046d&pid_081b&mi_00#7&206cb1df&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
chosen type: RGB24, usingFourCC: false, res: 1280x960 - 1280x960, fps: 5-30, fourCC: 00000000
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
Total frames rendered: 520, number of frames that lagged: 503 (96.73%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
bufferTime: 2843, outputRateWindowTime: 1000, dropThreshold: 3343
Warning -- MMDeviceAudioSource::GetBuffer: GetNextPacketSize failed
Total frames rendered: 19452, number of frames that lagged: 15297 (78.64%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
bufferTime: 4854, outputRateWindowTime: 1000, dropThreshold: 5354
Total frames rendered: 82893, number of frames that lagged: 79064 (95.38%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
bufferTime: 2585, outputRateWindowTime: 1000, dropThreshold: 3085
Total frames rendered: 3359, number of frames that lagged: 2864 (85.26%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 24
preset: veryfast
CBR: no
max bitrate: 800
buffer size: 800
quality: 7
Total frames rendered: 0, number of frames that lagged: 0 (-1.#J%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 49.581 ms] [avg calls per frame: 1] [children: 98.2%] [unaccounted: 1.77%]
| scene->Preprocess - [86.6%] [avg time: 42.944 ms] [avg calls per frame: 1]
| video encoding and uploading - [11.6%] [avg time: 5.758 ms] [avg calls per frame: 1] [children: 3.79%] [unaccounted: 7.83%]
| | CopyResource - [0.123%] [avg time: 0.061 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.00807%] [avg time: 0.004 ms] [avg calls per frame: 0]
| | call to encoder - [3.61%] [avg time: 1.789 ms] [avg calls per frame: 0]
| | sending stuff out - [0.0484%] [avg time: 0.024 ms] [avg calls per frame: 0]
Memory Leaks Were Detected.
