1. The new Windows 10 Hardware-accelerated GPU scheduling ("HAGS") added with version 2004 is currently known to cause performance and capture issues with OBS, games and overlay tools. It's a new and experimental feature and we recommend disabling it via
these instructions.
2. Uncheck the box for Psycho Visual Tuning.
3. Your log contains streaming sessions with dropped frames. This can only be caused by a failure in your internet connection or your networking hardware. It is not caused by OBS. Follow the troubleshooting steps at:
Dropped Frames and General Connection Issues. The easy fix in OBS is to go to Settings, Advanced, Network, check the box for "Dynamically change bitrate...", Apply, OK.
4. Multiple Game Capture sources are usually not needed, and can sometimes interfere with each other (scene "Scene"). You can use the same Game Capture for all your games! If you change games often, try out the hotkey mode, which lets you press a key to select your active game. If you play games in fullscreen, use 'Capture any fullscreen application' mode.
