Question / Help High encoding and sound errors suddenly...
nbones85
These issues have never happened before this computer is only a few months old and fairly top end but not warning high encoding happening all the time I cant seem to fix, or if I change things and fix for a day it comes back. also random audio delays where normally I have none sometimes I have to put a 5 second so everything matches up.
Please help, thanks.
01:45:16: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
01:45:16: CUDA loaded successfully
01:45:16: 1 CUDA capable devices found
01:45:16: [ GPU #0 - < GeForce GTX 970 > has Compute SM 5.2, NVENC Available ]
01:47:56: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
01:47:56: -------------------------------
01:47:56: CPU Name: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
01:47:56: CPU Speed: 4000MHz
01:47:56: Physical Memory: 4095MB Total, 4095MB Free
01:47:56: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
01:47:56: monitor 1: pos={0, 0}, size={1920, 1080}
01:47:56: monitor 2: pos={1920, 0}, size={1920, 1080}
01:47:56: Windows Version: 6.2 Build 9200
01:47:56: Aero is Enabled
01:47:56: OBS Modules:
01:47:56: Base Address Module
01:47:56: 00BD0000 OBS.exe
01:47:56: 6BA70000 OBSApi.dll
01:47:56: 6C190000 DShowPlugin.dll
01:47:56: 6C4A0000 GraphicsCapture.dll
01:47:56: 6C160000 NoiseGate.dll
01:47:56: 6C140000 PSVPlugin.dll
01:47:56: 6BDF0000 scenesw.dll
01:47:56: ------------------------------------------
01:47:56: Adapter 1
01:47:56: Video Adapter: NVIDIA GeForce GTX 970
01:47:56: Video Adapter Dedicated Video Memory: 3221225472
01:47:56: Video Adapter Shared System Memory: 1073676288
01:47:56: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
01:47:56: Video Adapter Output 2: pos={1920, 0}, size={1920, 1080}, attached=true
01:47:56: =====Stream Start: 2015-05-31, 01:47:56===============================================
01:47:56: Multithreaded optimizations: On
01:47:56: Base resolution: 1920x1080
01:47:56: Output resolution: 1920x1080
01:47:56: Loading up D3D10 on NVIDIA GeForce GTX 970 (Adapter 1)...
01:47:56: Audio Format: 48000 Hz
01:47:56: Audio Channels: 2 Ch
01:47:56: Playback device Default
01:47:56: Using desktop audio input: Speakers (2- High Definition Audio Device)
01:47:56: Global Audio time adjust: 0
01:47:56: Using auxilary audio input: Microphone (Yeti Stereo Microphone)
01:47:56: Mic time offset: 0
01:47:56: Audio Encoding: AAC
01:47:56: bitrate: 128
01:47:56: Using Slide Show
01:47:56: Scene buffering time set to 700
01:47:56: Video Encoding: x264
01:47:56: fps: 30
01:47:56: width: 1920, height: 1080
01:47:56: preset: veryfast
01:47:56: profile: main
01:47:56: keyint: 60
01:47:56: CBR: yes
01:47:56: CFR: yes
01:47:56: max bitrate: 3000
01:47:56: buffer size: 3000
01:48:30: ------------------------------------------
01:48:30: device: Elgato Game Capture HD,
01:48:30: device id {39F50F4C-99E1-464A-B6F9-D605B4FB5918},
01:48:30: chosen type: UYVY, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
01:48:30: use buffering: true - 0, fourCC: 'UYVY'
01:48:30:
01:48:30: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:48:30: Elgato Game Capture: force buffering with 1 msec
01:48:34: Using directshow input
01:49:30: Using text output
01:51:22: Using text output
Your log file is incomplete.
Elgato devices have all kinds of problems, you might search the forums to see if you can find yours.
