Hi i never had that problem before , i didnt instal other apps for streaming like it saying here
Slower preset in use
You have changed the default preset to faster. Using slower presets can result in late frames and high CPU usage / low FPS. You should only change the preset if you are sure you have the CPU power to spare.
Bad server selected
The server you are streaming to (rtmp://live-fra.twitch.tv/app) took a very long time to connect. This could be due to a poor connection, server problems or streaming to a server that is a long distance away from you. Streaming to servers that are closer to you often results in the best results. If you are using twitch.tv, try using JTVPing to find an optimal server.
Hook conflict detected
Game capture detected a hook conflict but was unable to determine which application was responsible. Try closing any other applications that may be injecting into your game, such as FRAPS, D3DGear, MSI Afterburner, AMD Raptr / Gaming Evolved, Action!, TeamSpeak/Mumble Overlays or any other kind of FPS monitor or overlay program
the best server for me is germany , i try the best server ping with JTVPing , the only programs what i have been haved opened was steam and obs ! my speed test is http://www.speedtest.net/my-result/4349808213
Bad server selected
