Question / Help Help with Stream Lag
hotpots
CBR and CBR padding are both enabled.
Will link logs in 1 sec
Currently streaming to London, UK, primary.
21:15:59: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
21:15:59: -------------------------------
21:15:59: CPU Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
21:15:59: CPU Speed: 3500MHz
21:15:59: Physical Memory:  4095MB Total, 4095MB Free
21:15:59: stepping id: 3, model 12, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
21:15:59: monitor 1: pos={0, 0}, size={1600, 900}
21:15:59: Windows Version: 6.1 Build 7601 S
21:15:59: Aero is Disabled
21:15:59: OBS Modules:
21:15:59: Base Address     Module
21:15:59: 00250000         OBS.exe
21:15:59: 6E3F0000         OBSApi.dll
21:15:59: 73BA0000         DShowPlugin.dll
21:15:59: 73A60000         GraphicsCapture.dll
21:15:59: 73A40000         NoiseGate.dll
21:15:59: 73A20000         PSVPlugin.dll
21:15:59: ------------------------------------------
21:15:59: Adapter 1
21:15:59:   Video Adapter: NVIDIA GeForce GTX 780
21:15:59:   Video Adapter Dedicated Video Memory: 3140157440
21:15:59:   Video Adapter Shared System Memory: 1154744320
21:15:59: =====Stream Start: 2013-08-14, 21:15:59===============================================
21:15:59:   Multithreaded optimizations: On
21:15:59:   Base resolution: 1600x900
21:15:59:   Output resolution: 1064x600
21:15:59: Loading up D3D10...
21:15:59: Playback device Default
21:15:59: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:15:59: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:15:59: Audio Encoding: AAC
21:15:59:     bitrate: 128
21:15:59: Using graphics capture
21:15:59: Video Encoding: x264
21:15:59:     fps: 60
21:15:59:     width: 1064, height: 600
21:15:59:     preset: veryfast
21:15:59:     CBR: yes
21:15:59:     CFR: no
21:15:59:     max bitrate: 1000
21:17:44: SharedTexCapture hooked
21:18:21: Total frames rendered: 8447, number of frames that lagged: 6 (0.07%) (it's okay for some frames to lag)
21:18:21: =====Stream End: 2013-08-14, 21:18:21=================================================
21:18:23: =====Stream Start: 2013-08-14, 21:18:23===============================================
21:18:23:   Multithreaded optimizations: On
21:18:23:   Base resolution: 1600x900
21:18:23:   Output resolution: 1064x600
21:18:23: ------------------------------------------
21:18:23: Loading up D3D10...
21:18:23: Playback device Default
21:18:23: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:18:23: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:18:23: Audio Encoding: AAC
21:18:23:     bitrate: 128
21:18:23: Using graphics capture
21:18:23: Video Encoding: x264
21:18:23:     fps: 60
21:18:23:     width: 1064, height: 600
21:18:23:     preset: veryfast
21:18:23:     CBR: yes
21:18:23:     CFR: no
21:18:23:     max bitrate: 1000
21:18:23: SharedTexCapture hooked
21:18:24: GraphicsCaptureSource::NewCapture:  eliminating old capture
21:18:24: SharedTexCapture hooked
21:18:24: Using RTMP service: Twitch / Justin.tv
21:18:24:   Server selection: rtmp://live-lhr.justin.tv/app
21:18:26: SO_SNDBUF was at 8192
21:18:26: SO_SNDBUF is now 65536
21:22:36: Total frames rendered: 15133, number of frames that lagged: 5 (0.03%) (it's okay for some frames to lag)
21:22:36: RTMPPublisher::SocketLoop: Aborting due to bStopping
21:22:36: Number of times waited to send: 0, Waited for a total of 0 bytes
21:22:36: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:22:36: =====Stream End: 2013-08-14, 21:22:36=================================================
21:26:06: =====Stream Start: 2013-08-14, 21:26:06===============================================
21:26:06:   Multithreaded optimizations: On
21:26:06:   Base resolution: 1600x900
21:26:06:   Output resolution: 1280x720
21:26:06: ------------------------------------------
21:26:06: Loading up D3D10...
21:26:06: Playback device Default
21:26:06: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:26:06: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:26:06: Audio Encoding: AAC
21:26:06:     bitrate: 128
21:26:06: Using graphics capture
21:26:06: Video Encoding: x264
21:26:06:     fps: 60
21:26:06:     width: 1280, height: 720
21:26:06:     preset: veryfast
21:26:06:     CBR: yes
21:26:06:     CFR: no
21:26:06:     max bitrate: 1500
21:26:06: SharedTexCapture hooked
21:26:12: Total frames rendered: 311, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
21:26:12: =====Stream End: 2013-08-14, 21:26:12=================================================
21:26:12: =====Stream Start: 2013-08-14, 21:26:12===============================================
21:26:12:   Multithreaded optimizations: On
21:26:12:   Base resolution: 1600x900
21:26:12:   Output resolution: 1280x720
21:26:12: ------------------------------------------
21:26:12: Loading up D3D10...
21:26:12: Playback device Default
21:26:12: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:26:12: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:26:12: Audio Encoding: AAC
21:26:12:     bitrate: 128
21:26:12: Using graphics capture
21:26:12: Video Encoding: x264
21:26:12:     fps: 60
21:26:12:     width: 1280, height: 720
21:26:12:     preset: veryfast
21:26:12:     CBR: yes
21:26:12:     CFR: no
21:26:12:     max bitrate: 1500
21:26:12: SharedTexCapture hooked
21:26:14: Using RTMP service: Twitch / Justin.tv
21:26:14:   Server selection: rtmp://live-lhr.justin.tv/app
21:26:14: GraphicsCaptureSource::NewCapture:  eliminating old capture
21:26:14: SharedTexCapture hooked
21:26:16: SO_SNDBUF was at 8192
21:26:16: SO_SNDBUF is now 65536
21:27:37: GraphicsCaptureSource::NewCapture:  eliminating old capture
21:27:37: SharedTexCapture hooked
21:27:46: Total frames rendered: 5515, number of frames that lagged: 8 (0.15%) (it's okay for some frames to lag)
21:27:46: RTMPPublisher::SocketLoop: Aborting due to loop exit
21:27:46: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
21:27:46: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
21:27:46: Number of times waited to send: 0, Waited for a total of 0 bytes
21:27:46: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:27:46: =====Stream End: 2013-08-14, 21:27:46=================================================
21:46:49: =====Stream Start: 2013-08-14, 21:46:49===============================================
21:46:49:   Multithreaded optimizations: On
21:46:49:   Base resolution: 1600x900
21:46:49:   Output resolution: 1064x600
21:46:49: ------------------------------------------
21:46:49: Loading up D3D10...
21:46:49: Playback device Default
21:46:49: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:46:49: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:46:49: Audio Encoding: AAC
21:46:49:     bitrate: 128
21:46:49: Using graphics capture
21:46:49: Video Encoding: x264
21:46:49:     fps: 60
21:46:49:     width: 1064, height: 600
21:46:49:     preset: veryfast
21:46:49:     CBR: yes
21:46:49:     CFR: no
21:46:49:     max bitrate: 3000
21:46:57: Using graphics capture
21:46:57: SharedTexCapture hooked
21:47:15: Total frames rendered: 1540, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
21:47:15: =====Stream End: 2013-08-14, 21:47:15=================================================
21:47:17: =====Stream Start: 2013-08-14, 21:47:17===============================================
21:47:17:   Multithreaded optimizations: On
21:47:17:   Base resolution: 1600x900
21:47:17:   Output resolution: 1064x600
21:47:17: ------------------------------------------
21:47:17: Loading up D3D10...
21:47:17: Playback device Default
21:47:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:47:17: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:47:17: Audio Encoding: AAC
21:47:17:     bitrate: 128
21:47:17: Using graphics capture
21:47:17: Video Encoding: x264
21:47:17:     fps: 60
21:47:17:     width: 1064, height: 600
21:47:17:     preset: veryfast
21:47:17:     CBR: yes
21:47:17:     CFR: no
21:47:17:     max bitrate: 3000
21:47:17: SharedTexCapture hooked
21:47:18: Using RTMP service: Twitch / Justin.tv
21:47:18:   Server selection: rtmp://live-lhr.justin.tv/app
21:47:20: SO_SNDBUF was at 8192
21:47:20: SO_SNDBUF is now 65536
21:49:29: Total frames rendered: 7926, number of frames that lagged: 3 (0.04%) (it's okay for some frames to lag)
21:49:29: RTMPPublisher::SocketLoop: Aborting due to bStopping
21:49:29: Number of times waited to send: 0, Waited for a total of 0 bytes
21:49:29: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:49:29: =====Stream End: 2013-08-14, 21:49:29=================================================
21:49:37: =====Stream Start: 2013-08-14, 21:49:37===============================================
21:49:37:   Multithreaded optimizations: On
21:49:37:   Base resolution: 1600x900
21:49:37:   Output resolution: 1280x720
21:49:37: ------------------------------------------
21:49:37: Loading up D3D10...
21:49:37: Playback device Default
21:49:37: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:49:37: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:49:38: ------------------------------------------
21:49:38: Audio Encoding: AAC
21:49:38:     bitrate: 128
21:49:38: Using graphics capture
21:49:38: Video Encoding: x264
21:49:38:     fps: 60
21:49:38:     width: 1280, height: 720
21:49:38:     preset: veryfast
21:49:38:     CBR: yes
21:49:38:     CFR: no
21:49:38:     max bitrate: 3000
21:49:38: SharedTexCapture hooked
21:49:39: Using RTMP service: Twitch / Justin.tv
21:49:39:   Server selection: rtmp://live-lhr.justin.tv/app
21:49:41: SO_SNDBUF was at 8192
21:49:41: SO_SNDBUF is now 65536
21:52:06: Total frames rendered: 8899, number of frames that lagged: 2 (0.02%) (it's okay for some frames to lag)
21:52:06: RTMPPublisher::SocketLoop: Aborting due to bStopping
21:52:06: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
21:52:06: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
21:52:06: Number of times waited to send: 2, Waited for a total of 1562 bytes
21:52:06: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:52:06: =====Stream End: 2013-08-14, 21:52:06=================================================
21:53:36: =====Stream Start: 2013-08-14, 21:53:36===============================================
21:53:36:   Multithreaded optimizations: On
21:53:36:   Base resolution: 1600x900
21:53:36:   Output resolution: 1600x900
21:53:36: ------------------------------------------
21:53:36: Loading up D3D10...
21:53:36: Playback device Default
21:53:36: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:53:36: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:53:36: Audio Encoding: AAC
21:53:36:     bitrate: 128
21:53:36: Using graphics capture
21:53:36: Video Encoding: x264
21:53:36:     fps: 60
21:53:36:     width: 1600, height: 900
21:53:36:     preset: veryfast
21:53:36:     CBR: yes
21:53:36:     CFR: no
21:53:36:     max bitrate: 3000
21:53:36: SharedTexCapture hooked
21:53:37: Using RTMP service: Twitch / Justin.tv
21:53:37:   Server selection: rtmp://live-lhr.justin.tv/app
21:53:39: SO_SNDBUF was at 8192
21:53:39: SO_SNDBUF is now 65536
22:00:10: Total frames rendered: 23612, number of frames that lagged: 2 (0.01%) (it's okay for some frames to lag)
22:00:10: RTMPPublisher::SocketLoop: Aborting due to bStopping
22:00:10: Number of times waited to send: 0, Waited for a total of 0 bytes
22:00:10: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:00:10: =====Stream End: 2013-08-14, 22:00:10=================================================
22:01:30:
22:01:30: Profiler results:
22:01:30:
22:01:30: ==============================================================
22:01:30: frame - [100%] [avg time: 1.346 ms (cpu time: avg 1.083 ms, total 77376.5 ms)] [avg calls per frame: 1] [children: 99.7%] [unaccounted: 0.297%]
22:01:30: | frame preprocessing and rendering - [23.8%] [avg time: 0.32 ms (cpu time: avg 0.212 ms, total 15178.9 ms)] [avg calls per frame: 1] [children: 0.0743%] [unaccounted: 23.7%]
22:01:30: | | scene->Preprocess - [0.0743%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 31.201 ms)] [avg calls per frame: 1]
22:01:30: | video encoding and uploading - [75.9%] [avg time: 1.022 ms (cpu time: avg 0.869 ms, total 62041.6 ms)] [avg calls per frame: 1] [children: 74.5%] [unaccounted: 1.41%]
22:01:30: | | flush - [9.29%] [avg time: 0.125 ms (cpu time: avg 0.039 ms, total 2792.42 ms)] [avg calls per frame: 1]
22:01:30: | | CopyResource - [0.594%] [avg time: 0.008 ms (cpu time: avg 0.006 ms, total 499.201 ms)] [avg calls per frame: 0]
22:01:30: | | conversion to 4:2:0 - [0.52%] [avg time: 0.007 ms (cpu time: avg 0.004 ms, total 343.203 ms)] [avg calls per frame: 0]
22:01:30: | | call to encoder - [63%] [avg time: 0.848 ms (cpu time: avg 0.802 ms, total 57299.2 ms)] [avg calls per frame: 0]
22:01:30: | | sending stuff out - [1.11%] [avg time: 0.015 ms (cpu time: avg 0.005 ms, total 374.4 ms)] [avg calls per frame: 0]
22:01:30: | Convert444Threads - [2.48e+003%] [avg time: 33.331 ms (cpu time: avg 0.835 ms, total 59654.8 ms)] [avg calls per frame: 1]
22:01:30:
hotpots
18:42:38: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
18:42:38: -------------------------------
18:42:38: CPU Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
18:42:38: CPU Speed: 3500MHz
18:42:38: Physical Memory:  4095MB Total, 4095MB Free
18:42:38: stepping id: 3, model 12, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
18:42:38: monitor 1: pos={0, 0}, size={1600, 900}
18:42:38: Windows Version: 6.1 Build 7601 S
18:42:38: Aero is Disabled
18:42:38: OBS Modules:
18:42:38: Base Address     Module
18:42:38: 01310000         OBS.exe
18:42:38: 6E340000         OBSApi.dll
18:42:38: 72450000         DShowPlugin.dll
18:42:38: 72030000         GraphicsCapture.dll
18:42:38: 72010000         NoiseGate.dll
18:42:38: 71FF0000         PSVPlugin.dll
18:42:38: ------------------------------------------
18:42:38: Adapter 1
18:42:38:   Video Adapter: NVIDIA GeForce GTX 780
18:42:38:   Video Adapter Dedicated Video Memory: 3140157440
18:42:38:   Video Adapter Shared System Memory: 1154744320
18:42:38: =====Stream Start: 2013-08-14, 18:42:38===============================================
18:42:38:   Multithreaded optimizations: On
18:42:38:   Base resolution: 1600x900
18:42:38:   Output resolution: 1600x900
18:42:38: Loading up D3D10...
18:42:38: Playback device Default
18:42:38: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:42:38: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:42:38: Audio Encoding: AAC
18:42:38:     bitrate: 256
18:42:38: Using graphics capture
18:42:38: Video Encoding: x264
18:42:38:     fps: 60
18:42:38:     width: 1600, height: 900
18:42:38:     preset: veryfast
18:42:38:     CBR: yes
18:42:38:     CFR: no
18:42:38:     max bitrate: 3500
18:42:40: Using RTMP service: Twitch / Justin.tv
18:42:40:   Server selection: rtmp://live-lhr.justin.tv/app
18:42:43: SO_SNDBUF was at 8192
18:42:43: SO_SNDBUF is now 65536
18:42:46: Total frames rendered: 450, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
18:42:46: RTMPPublisher::SocketLoop: Aborting due to bStopping
18:42:46: Number of times waited to send: 0, Waited for a total of 0 bytes
18:42:46: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:42:46: =====Stream End: 2013-08-14, 18:42:46=================================================
18:43:00: =====Stream Start: 2013-08-14, 18:43:00===============================================
18:43:00:   Multithreaded optimizations: On
18:43:00:   Base resolution: 1600x900
18:43:00:   Output resolution: 1600x900
18:43:00: ------------------------------------------
18:43:00: Loading up D3D10...
18:43:00: Playback device Default
18:43:00: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:43:00: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:43:00: Audio Encoding: AAC
18:43:00:     bitrate: 256
18:43:00: Using graphics capture
18:43:00: Video Encoding: x264
18:43:00:     fps: 60
18:43:00:     width: 1600, height: 900
18:43:00:     preset: veryfast
18:43:00:     CBR: yes
18:43:00:     CFR: no
18:43:00:     max bitrate: 3500
18:43:00: SharedTexCapture hooked
18:43:01: Using RTMP service: Twitch / Justin.tv
18:43:01:   Server selection: rtmp://live-lhr.justin.tv/app
18:43:04: SO_SNDBUF was at 8192
18:43:04: SO_SNDBUF is now 65536
18:43:05: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:43:05: SharedTexCapture hooked
18:43:06: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:43:06: SharedTexCapture hooked
18:45:32: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:45:32: SharedTexCapture hooked
18:46:38: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:46:38: SharedTexCapture hooked
18:46:39: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:46:39: SharedTexCapture hooked
18:48:56: Capture window 0x000B004A invalid or changing, terminating capture
18:49:00: SharedTexCapture hooked
18:52:56: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:52:56: SharedTexCapture hooked
18:53:01: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:53:01: SharedTexCapture hooked
18:53:02: SharedTexCapture hooked
19:00:49: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:00:49: SharedTexCapture hooked
19:01:48: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:01:48: SharedTexCapture hooked
19:01:49: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:01:49: SharedTexCapture hooked
19:02:26: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:02:26: SharedTexCapture hooked
19:20:14: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:20:14: SharedTexCapture hooked
19:20:15: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:20:15: SharedTexCapture hooked
19:26:12: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:26:12: SharedTexCapture hooked
19:26:24: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:26:24: SharedTexCapture hooked
19:26:25: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:26:25: SharedTexCapture hooked
19:40:34: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
19:52:29: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:52:29: SharedTexCapture hooked
19:52:30: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:52:30: SharedTexCapture hooked
19:53:11: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:53:11: SharedTexCapture hooked
19:59:52: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:59:52: SharedTexCapture hooked
19:59:54: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:59:54: SharedTexCapture hooked
20:19:47: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:19:47: SharedTexCapture hooked
20:20:03: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:20:03: SharedTexCapture hooked
20:20:13: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:20:13: SharedTexCapture hooked
20:20:14: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:20:14: SharedTexCapture hooked
20:21:28: Capture window 0x000C004A invalid or changing, terminating capture
20:21:33: Total frames rendered: 353919, number of frames that lagged: 143 (0.04%) (it's okay for some frames to lag)
20:21:33: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:21:33: Number of times waited to send: 40, Waited for a total of 156343 bytes
20:21:33: Number of b-frames dropped: 89 (0.025%), Number of p-frames dropped: 101 (0.029%), Total 190 (0.054%)
20:21:33: =====Stream End: 2013-08-14, 20:21:33=================================================
20:28:44: =====Stream Start: 2013-08-14, 20:28:44===============================================
20:28:44:   Multithreaded optimizations: On
20:28:44:   Base resolution: 1600x900
20:28:44:   Output resolution: 1280x720
20:28:44: ------------------------------------------
20:28:44: Loading up D3D10...
20:28:44: Playback device Default
20:28:44: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:28:44: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:28:44: Audio Encoding: AAC
20:28:44:     bitrate: 256
20:28:44: Using graphics capture
20:28:44: Video Encoding: x264
20:28:44:     fps: 60
20:28:44:     width: 1280, height: 720
20:28:44:     preset: veryfast
20:28:44:     CBR: yes
20:28:44:     CFR: no
20:28:44:     max bitrate: 3500
20:28:44: SharedTexCapture hooked
20:28:48: Total frames rendered: 248, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
20:28:48: =====Stream End: 2013-08-14, 20:28:48=================================================
20:28:50: =====Stream Start: 2013-08-14, 20:28:50===============================================
20:28:50:   Multithreaded optimizations: On
20:28:50:   Base resolution: 1600x900
20:28:50:   Output resolution: 1280x720
20:28:50: ------------------------------------------
20:28:50: Loading up D3D10...
20:28:50: Playback device Default
20:28:50: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:28:50: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:28:50: Audio Encoding: AAC
20:28:50:     bitrate: 256
20:28:50: Using graphics capture
20:28:50: Video Encoding: x264
20:28:50:     fps: 60
20:28:50:     width: 1280, height: 720
20:28:50:     preset: veryfast
20:28:50:     CBR: yes
20:28:50:     CFR: no
20:28:50:     max bitrate: 3500
20:28:50: SharedTexCapture hooked
20:28:51: Using RTMP service: Twitch / Justin.tv
20:28:51:   Server selection: rtmp://live-lhr.justin.tv/app
20:28:53: SO_SNDBUF was at 8192
20:28:53: SO_SNDBUF is now 65536
20:30:52: Total frames rendered: 7300, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
20:30:52: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:30:52: Number of times waited to send: 8, Waited for a total of 26808 bytes
20:30:52: Number of b-frames dropped: 6 (0.085%), Number of p-frames dropped: 0 (0%), Total 6 (0.085%)
20:30:52: =====Stream End: 2013-08-14, 20:30:52=================================================
20:31:24: =====Stream Start: 2013-08-14, 20:31:24===============================================
20:31:24:   Multithreaded optimizations: On
20:31:24:   Base resolution: 1600x900
20:31:24:   Output resolution: 1600x900
20:31:24: ------------------------------------------
20:31:24: Loading up D3D10...
20:31:24: Playback device Default
20:31:24: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:31:24: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:31:24: Audio Encoding: AAC
20:31:24:     bitrate: 256
20:31:24: Using graphics capture
20:31:24: Video Encoding: x264
20:31:24:     fps: 60
20:31:24:     width: 1600, height: 900
20:31:24:     preset: veryfast
20:31:24:     CBR: yes
20:31:24:     CFR: no
20:31:24:     max bitrate: 3500
20:31:24: SharedTexCapture hooked
20:31:26: Using RTMP service: Twitch / Justin.tv
20:31:26:   Server selection: rtmp://live-lhr.justin.tv/app
20:31:27: SO_SNDBUF was at 8192
20:31:27: SO_SNDBUF is now 65536
20:31:34: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
20:34:18: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 1048576
20:36:33: Total frames rendered: 18551, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
20:36:33: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:36:33: Number of times waited to send: 5, Waited for a total of 20485 bytes
20:36:33: Number of b-frames dropped: 99 (0.54%), Number of p-frames dropped: 129 (0.7%), Total 228 (1.2%)
20:36:33: =====Stream End: 2013-08-14, 20:36:33=================================================
20:38:33: =====Stream Start: 2013-08-14, 20:38:33===============================================
20:38:33:   Multithreaded optimizations: On
20:38:33:   Base resolution: 1600x900
20:38:33:   Output resolution: 1600x900
20:38:33: ------------------------------------------
20:38:33: Loading up D3D10...
20:38:33: Playback device Default
20:38:33: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:38:33: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:38:33: Audio Encoding: AAC
20:38:33:     bitrate: 256
20:38:33: Using graphics capture
20:38:33: Video Encoding: x264
20:38:33:     fps: 60
20:38:33:     width: 1600, height: 900
20:38:33:     preset: veryfast
20:38:33:     CBR: yes
20:38:33:     CFR: no
20:38:33:     max bitrate: 3000
20:38:33: SharedTexCapture hooked
20:39:48: Total frames rendered: 4482, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
20:39:48: =====Stream End: 2013-08-14, 20:39:48=================================================
20:41:12: =====Stream Start: 2013-08-14, 20:41:12===============================================
20:41:12:   Multithreaded optimizations: On
20:41:12:   Base resolution: 1600x900
20:41:12:   Output resolution: 1600x900
20:41:12: ------------------------------------------
20:41:12: Loading up D3D10...
20:41:12: Playback device Default
20:41:12: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:41:12: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:41:12: Audio Encoding: AAC
20:41:12:     bitrate: 256
20:41:12: Using graphics capture
20:41:12: Video Encoding: x264
20:41:12:     fps: 60
20:41:12:     width: 1600, height: 900
20:41:12:     preset: veryfast
20:41:12:     CBR: yes
20:41:12:     CFR: no
20:41:12:     max bitrate: 3000
20:41:12: SharedTexCapture hooked
20:41:14: Using RTMP service: Twitch / Justin.tv
20:41:14:   Server selection: rtmp://live-lhr.justin.tv/app
20:41:14: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:41:14: SharedTexCapture hooked
20:41:16: SO_SNDBUF was at 8192
20:41:16: SO_SNDBUF is now 65536
20:43:22: Total frames rendered: 7779, number of frames that lagged: 6 (0.08%) (it's okay for some frames to lag)
20:43:22: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:43:22: Number of times waited to send: 0, Waited for a total of 0 bytes
20:43:22: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:43:22: =====Stream End: 2013-08-14, 20:43:22=================================================
20:44:02: =====Stream Start: 2013-08-14, 20:44:02===============================================
20:44:02:   Multithreaded optimizations: On
20:44:02:   Base resolution: 1600x900
20:44:02:   Output resolution: 1600x900
20:44:02: ------------------------------------------
20:44:02: Loading up D3D10...
20:44:02: Playback device Default
20:44:02: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:44:02: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:44:02: Audio Encoding: AAC
20:44:02:     bitrate: 256
20:44:02: Using graphics capture
20:44:02: Video Encoding: x264
20:44:02:     fps: 60
20:44:02:     width: 1600, height: 900
20:44:02:     preset: veryfast
20:44:02:     CBR: yes
20:44:02:     CFR: no
20:44:02:     max bitrate: 2500
20:44:02: SharedTexCapture hooked
20:44:03: Using RTMP service: Twitch / Justin.tv
20:44:03:   Server selection: rtmp://live-lhr.justin.tv/app
20:44:04: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:44:04: SharedTexCapture hooked
20:44:08: SO_SNDBUF was at 8192
20:44:08: SO_SNDBUF is now 65536
20:46:52: Total frames rendered: 10188, number of frames that lagged: 6 (0.06%) (it's okay for some frames to lag)
20:46:52: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:46:52: Number of times waited to send: 0, Waited for a total of 0 bytes
20:46:52: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:46:52: =====Stream End: 2013-08-14, 20:46:52=================================================
20:47:38: =====Stream Start: 2013-08-14, 20:47:38===============================================
20:47:38:   Multithreaded optimizations: On
20:47:38:   Base resolution: 1600x900
20:47:38:   Output resolution: 1600x900
20:47:38: ------------------------------------------
20:47:38: Loading up D3D10...
20:47:38: Playback device Default
20:47:38: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:47:38: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:47:38: Audio Encoding: AAC
20:47:38:     bitrate: 256
20:47:38: Using graphics capture
20:47:38: Video Encoding: x264
20:47:38:     fps: 30
20:47:38:     width: 1600, height: 900
20:47:38:     preset: veryfast
20:47:38:     CBR: yes
20:47:38:     CFR: no
20:47:38:     max bitrate: 3500
20:47:38: SharedTexCapture hooked
20:47:39: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:47:39: SharedTexCapture hooked
20:47:40: Using RTMP service: Twitch / Justin.tv
20:47:40:   Server selection: rtmp://live-lhr.justin.tv/app
20:47:42: SO_SNDBUF was at 8192
20:47:42: SO_SNDBUF is now 65536
20:48:49: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
20:50:21: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:50:21: SharedTexCapture hooked
20:50:32: Total frames rendered: 5180, number of frames that lagged: 8 (0.15%) (it's okay for some frames to lag)
20:50:32: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:50:32: Number of times waited to send: 8, Waited for a total of 30932 bytes
20:50:32: Number of b-frames dropped: 5 (0.099%), Number of p-frames dropped: 0 (0%), Total 5 (0.099%)
20:50:32: =====Stream End: 2013-08-14, 20:50:32=================================================
20:50:33: =====Stream Start: 2013-08-14, 20:50:33===============================================
20:50:33:   Multithreaded optimizations: On
20:50:33:   Base resolution: 1600x900
20:50:33:   Output resolution: 1600x900
20:50:33: ------------------------------------------
20:50:33: Loading up D3D10...
20:50:33: Playback device Default
20:50:33: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:50:33: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:50:33: Audio Encoding: AAC
20:50:33:     bitrate: 256
20:50:33: Using graphics capture
20:50:33: Video Encoding: x264
20:50:33:     fps: 30
20:50:33:     width: 1600, height: 900
20:50:33:     preset: veryfast
20:50:33:     CBR: yes
20:50:33:     CFR: no
20:50:33:     max bitrate: 3500
20:50:33: SharedTexCapture hooked
20:50:47: Total frames rendered: 427, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
20:50:47: =====Stream End: 2013-08-14, 20:50:47=================================================
20:50:47: =====Stream Start: 2013-08-14, 20:50:47===============================================
20:50:47:   Multithreaded optimizations: On
20:50:47:   Base resolution: 1600x900
20:50:47:   Output resolution: 1600x900
20:50:47: ------------------------------------------
20:50:47: Loading up D3D10...
20:50:47: Playback device Default
20:50:47: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:50:47: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:50:47: Audio Encoding: AAC
20:50:47:     bitrate: 256
20:50:47: Using graphics capture
20:50:47: Video Encoding: x264
20:50:47:     fps: 60
20:50:47:     width: 1600, height: 900
20:50:47:     preset: veryfast
20:50:47:     CBR: yes
20:50:47:     CFR: no
20:50:47:     max bitrate: 3500
20:50:47: SharedTexCapture hooked
21:00:37: Exit signal received, terminating capture
21:06:15: Total frames rendered: 55646, number of frames that lagged: 2 (0.00%) (it's okay for some frames to lag)
21:06:15: =====Stream End: 2013-08-14, 21:06:15=================================================
21:06:15:
21:06:15: Profiler results:
21:06:15:
21:06:15: ==============================================================
21:06:15: frame - [100%] [avg time: 1.622 ms (cpu time: avg 1.445 ms, total 671038 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.247%]
21:06:15: | frame preprocessing and rendering - [17.1%] [avg time: 0.278 ms (cpu time: avg 0.197 ms, total 91853.4 ms)] [avg calls per frame: 1] [children: 0.0617%] [unaccounted: 17.1%]
21:06:15: | | scene->Preprocess - [0.0617%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 421.203 ms)] [avg calls per frame: 1]
21:06:15: | video encoding and uploading - [82.6%] [avg time: 1.34 ms (cpu time: avg 1.246 ms, total 578452 ms)] [avg calls per frame: 1] [children: 81.6%] [unaccounted: 0.986%]
21:06:15: | | flush - [5.73%] [avg time: 0.093 ms (cpu time: avg 0.043 ms, total 20342.6 ms)] [avg calls per frame: 1]
21:06:15: | | CopyResource - [0.432%] [avg time: 0.007 ms (cpu time: avg 0.007 ms, total 3556.82 ms)] [avg calls per frame: 0]
21:06:15: | | conversion to 4:2:0 - [0.37%] [avg time: 0.006 ms (cpu time: avg 0.004 ms, total 1981.21 ms)] [avg calls per frame: 0]
21:06:15: | | call to encoder - [74%] [avg time: 1.2 ms (cpu time: avg 1.172 ms, total 544288 ms)] [avg calls per frame: 0]
21:06:15: | | sending stuff out - [1.11%] [avg time: 0.018 ms (cpu time: avg 0.008 ms, total 3884.43 ms)] [avg calls per frame: 0]
21:06:15: | Convert444Threads - [2.08e+003%] [avg time: 33.783 ms (cpu time: avg 1.341 ms, total 622850 ms)] [avg calls per frame: 1]
21:06:15:
22:01:52: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
22:01:52: -------------------------------
22:01:52: CPU Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
22:01:52: CPU Speed: 3500MHz
22:01:52: Physical Memory:  4095MB Total, 4095MB Free
22:01:52: stepping id: 3, model 12, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
22:01:52: monitor 1: pos={0, 0}, size={1600, 900}
22:01:52: Windows Version: 6.1 Build 7601 S
22:01:52: Aero is Disabled
22:01:52: OBS Modules:
22:01:52: Base Address     Module
22:01:52: 008C0000         OBS.exe
22:01:52: 6C2A0000         OBSApi.dll
22:01:52: 73BD0000         DShowPlugin.dll
22:01:52: 73AB0000         GraphicsCapture.dll
22:01:52: 73A90000         NoiseGate.dll
22:01:52: 737F0000         PSVPlugin.dll
22:01:52: ------------------------------------------
22:01:52: Adapter 1
22:01:52:   Video Adapter: NVIDIA GeForce GTX 780
22:01:52:   Video Adapter Dedicated Video Memory: 3140157440
22:01:52:   Video Adapter Shared System Memory: 1154744320
22:01:52: =====Stream Start: 2013-08-14, 22:01:52===============================================
22:01:52:   Multithreaded optimizations: On
22:01:52:   Base resolution: 1600x900
22:01:52:   Output resolution: 1600x900
22:01:52: Loading up D3D10...
22:01:52: Playback device Default
22:01:52: Using desktop audio input: Speakers (Realtek High Definition Audio)
22:01:52: Using auxilary audio input: Microphone (Realtek High Definition Audio)
22:01:52: Audio Encoding: AAC
22:01:52:     bitrate: 128
22:01:52: Using graphics capture
22:01:52: Video Encoding: x264
22:01:52:     fps: 60
22:01:52:     width: 1600, height: 900
22:01:52:     preset: veryfast
22:01:52:     CBR: yes
22:01:52:     CFR: no
22:01:52:     max bitrate: 3000
22:01:52: SharedTexCapture hooked
22:01:53: Using RTMP service: Twitch / Justin.tv
22:01:53:   Server selection: rtmp://live-lhr.justin.tv/app
22:01:55: SO_SNDBUF was at 8192
22:01:55: SO_SNDBUF is now 65536
22:12:35: Total frames rendered: 38502, number of frames that lagged: 5 (0.01%) (it's okay for some frames to lag)
22:12:35: RTMPPublisher::SocketLoop: Aborting due to bStopping
22:12:35: Number of times waited to send: 0, Waited for a total of 0 bytes
22:12:35: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:12:35: =====Stream End: 2013-08-14, 22:12:35=================================================
22:16:12:
22:16:12: Profiler results:
22:16:12:
22:16:12: ==============================================================
22:16:12: frame - [100%] [avg time: 1.717 ms (cpu time: avg 1.447 ms, total 55739.2 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.233%]
22:16:12: | frame preprocessing and rendering - [17.9%] [avg time: 0.307 ms (cpu time: avg 0.22 ms, total 8502.06 ms)] [avg calls per frame: 1] [children: 0.0582%] [unaccounted: 17.8%]
22:16:12: | | scene->Preprocess - [0.0582%] [avg time: 0.001 ms (cpu time: avg 0.002 ms, total 78 ms)] [avg calls per frame: 1]
22:16:12: | video encoding and uploading - [81.9%] [avg time: 1.406 ms (cpu time: avg 1.223 ms, total 47096.7 ms)] [avg calls per frame: 1] [children: 81%] [unaccounted: 0.932%]
22:16:12: | | flush - [8.91%] [avg time: 0.153 ms (cpu time: avg 0.04 ms, total 1575.62 ms)] [avg calls per frame: 1]
22:16:12: | | CopyResource - [0.466%] [avg time: 0.008 ms (cpu time: avg 0.005 ms, total 202.801 ms)] [avg calls per frame: 0]
22:16:12: | | conversion to 4:2:0 - [0.349%] [avg time: 0.006 ms (cpu time: avg 0.003 ms, total 124.801 ms)] [avg calls per frame: 0]
22:16:12: | | call to encoder - [69.9%] [avg time: 1.2 ms (cpu time: avg 1.156 ms, total 44522.7 ms)] [avg calls per frame: 0]
22:16:12: | | sending stuff out - [1.34%] [avg time: 0.023 ms (cpu time: avg 0.008 ms, total 312.001 ms)] [avg calls per frame: 0]
22:16:12: | Convert444Threads - [1.94e+003%] [avg time: 33.354 ms (cpu time: avg 1.264 ms, total 48687.9 ms)] [avg calls per frame: 1]
22:16:12:
shall i try the server as amsterdam?
as...
Bitrate: 300
Quality: 10
Use CBR: Enabled
Enable CBR Padding - Enabled
Use Custom Buffer Size - Disabled
Codec - AAC Bitrate - 128
1600x900 no downscale
60fps
I really appreciate your help!
alpinlol
cant see any dropped frames ... and the amount of lagged frames is pretty much perfect
settings are fine
only thing you can do is change twitch server to the NL server but you gotta remember that currently LCS is going on so twitch kinda says fuck you non partners live with it your stream doesnt get any support out of our servers right now
alpinlol
says your stream is offline
and yes thats how twitch has always been but if its true what they posted on their blog then they are going to improve their european datacenters and even get more datacenters down in europe to fix their problems (FINALLY)
alpinlol
looking pretty much prefect to me though obviously a little quality loss but thats how it is with 3k bitrate and this resolution with 60fps ...
also didnt lag so far for me
hotpots
hmmm ok!
watching it right now from a 2nd gen i3 laptop with intel hd 3000 gfx. and its laggy... (sharing same internet con) dunno if that makes a diff
Will ask friends later to see what they think!
Maybe you just have excellent internet/comp i dunno :/
Thanks alot for your help, will get back if friends think its laggy too or if it doesnt clear up after lcs if it is a lil bit...
AND, thanks ALOT for your help, hope it is sorted! ;/ and its just this laptop :P
alpinlol
well probably because your cpu is peaking at 100% ;D
since my laptop is pretty much a bullshit dualcore and whenever i watch me streaming (1080p@60) i cant really watch it because its laggy as fuck but the recorded broadcast is perfect and also when i run my own stream on the 2nd screen its also perfectly smooth. so its pretty much the cpu peaking 100% because the flash player is shit.
but usually the i3 shouldnt have a problem since they are dual core with ht
alpinlol
so still not a single lagg for me
btw since you got such a freaking good hardware you should consider to get an actualy good monitor with 16:9 ratio and not 16:10 :P
hotpots
ok well watched it on my sisters comp, obviously sharing internet connection, with the laptop, my comp and hers.
And its still laggy, her specs below:
FX 8350 - Processor
Radeon 7870 - GFX Card.
Will ask friends later! :)
EDIT: as for the monitor, accidently bought the wrong one :P Will get a hdmi 22" this month some time, i hope! and use this one as a second one!
