HELP TRAKTOR Vs OBS: Encoding Problem with external source routing only(phono, cd.. >> to streaming): ASIO encoding !
musicAirline
Hi Every one Sorry for my English If some one is french: Bonjour,
Im Playing recently with TRAKTOR KONTROL S4mk3 switching to a platform for "Live"... With this new controller my setup is simple: TraKtor Pro 3 via Kontrol S4 Mk3 + Scarlett 2i2 sound card... Via OBS (or streamlab OBS same problm)
Since this new controller I have not been able to include an external source in my SETUP (type: Phono or CDJ turntable for CD format) and be able to enjoy my 4 decks !
In pure Live: In an ASIO configuration and without StreamLab & OBS encoding this poses no problems; But as soon as I switch to StreamLab or OBS only WDM encoding is supported (?!) and my external sources are no longer routed and therefore NOT CONNECTED
How can I simply enjoy external sources on Streamlab & OBS while playing on TRAKTOR (native instrument)?
THANK YOU so mush FOR YOUR HELP
PaiSand
You should contact Traktor support as it seams to be an issue within this product.
Issues with streamlabs products or services should be conducted to their support either.
