Help regarding bit rate suddenly dropping drastically
Pounds
Hello,
I've recently been experiencing a major issue while streaming to Twitch.
After I'd go live (or do a Bandwith Test stream), my bitrate would suddenly switch from being in the green with no dropped frames to red and about 95% of my frames dropped, thus making it completely impossible for me to stream. From what I can tell it's not happening when I perform a specific action so I don't know what the cause is. Whenever this happened I checked my internet connection and it seemed to be fine. This issue is new, as I've streamed before and it worked perfectly fine, but this has started happening lately which really frustrates me as I had just gotten affiliated on Twitch.
I've looked at the recources provided in the Help Portal and forums, and from my understanding there could be several issues that could be causing this, but I simply do not have the knowledge required to figure out what is the cause and how to resolve it.
Is there some sort of log file I could provide to help ferther identify the issue? Any help would be appriciated.
Thanks in advance!
Didn't really tell me anything new :/
If someone can help me point out the issue more specifically that'd help, otherwise I appreciate your time.
