Question / Help Help recently OBS Disconnecting from Twitch
Toonation
After April 29th for some reason my OBS disconnects from Twitch for some weird reason. I even Connected directly into the Ethernet and had the same problem there. Verizon is the ISP.
Here is what the log showed tonight
All of 5/5 including not live stuff etc
Here is speed test.net
Here is Twitch bandwidth Test
Glasnost Test with FlashVideo
As perviously mentioned I tested with Ethernet as well same problem occured
Changing Servers did not see to work
Lowering bit rate did not seem to work either
Wireless and Ethernet having same issue
Disabled and Even Deleted Antivirus
Updated drivers and deleted applications installed and around April 29th
No I do not have steam or any down load client open
Yes there's a second PC in the house but I turn it off or close all applications on it before streaming
I reset stream Key
