Question / Help HELP! OBS has FPS Problems!!
gewoonmika
On my game i have 120 FPS and on my obs i have 29fps but the output is on 60fps!! Can somebady help me?
Her is my log:
18:55:05.303: CPU Name: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
18:55:05.303: CPU Speed: 4008MHz
18:55:05.303: Physical Cores: 6, Logical Cores: 12
18:55:05.303: Physical Memory: 16329MB Total, 7963MB Free
18:55:05.303: Windows Version: 10.0 Build 17134 (revision: 167; 64-bit)
18:55:05.303: Running as administrator: false
18:55:05.303: Aero is Enabled (Aero is always on for windows 8 and above)
18:55:05.303: Windows 10 Gaming Features:
18:55:05.303: Game Bar: Off
18:55:05.303: Game DVR: Off
18:55:05.303: Game DVR Background Recording: Off
18:55:05.304: Sec. Software Status:
18:55:05.305: Windows Defender Antivirus: disabled (AV)
18:55:05.305: ESET Security: enabled (AV)
18:55:05.305: ESET Firewall: enabled (FW)
18:55:05.305: Windows Firewall: disabled (FW)
18:55:05.306: ESET Security: enabled (ASW)
18:55:05.306: Windows Defender Antivirus: disabled (ASW)
18:55:05.306: Portable mode: false
18:55:05.380: OBS 21.1.2 (64bit, windows)
18:55:05.380: ---------------------------------
18:55:05.390: ---------------------------------
18:55:05.390: audio settings reset:
18:55:05.390: samples per sec: 44100
18:55:05.390: speakers: 2
18:55:05.391: ---------------------------------
18:55:05.391: Initializing D3D11...
18:55:05.391: Available Video Adapters:
18:55:05.392: Adapter 1: NVIDIA GeForce GTX 970
18:55:05.392: Dedicated VRAM: 4239917056
18:55:05.392: Shared VRAM: 4266508288
18:55:05.392: output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:55:05.392: output 2: pos={1920, 0}, size={1920, 1080}, attached=true
18:55:05.392: output 3: pos={-1920, 0}, size={1920, 1080}, attached=true
18:55:05.393: Loading up D3D11 on adapter NVIDIA GeForce GTX 970 (0)
18:55:05.424: D3D11 loaded successfully, feature level used: 45056
18:55:05.959: ---------------------------------
18:55:05.959: video settings reset:
18:55:05.959: base resolution: 1920x1080
18:55:05.959: output resolution: 1920x1080
18:55:05.959: downscale filter: Bicubic
18:55:05.959: fps: 60/1
18:55:05.959: format: NV12
18:55:05.959: YUV mode: 601/Partial
18:55:05.960: Audio monitoring device:
18:55:05.960: name: Standaard
18:55:05.960: id: default
18:55:05.960: ---------------------------------
18:55:05.962: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
18:55:05.964: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:55:05.990: [AMF] AMF Test failed due to one or more errors.
18:55:05.990: Failed to initialize module 'enc-amf.dll'
18:55:06.001: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
18:55:06.002: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': (null) (127)
18:55:06.002: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
18:55:06.003: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
18:55:06.005: [browser_source: 'Version: 1.31.0']
18:55:06.010: NVENC supported
18:55:06.083: VLC found, VLC video source enabled
18:55:06.086: No blackmagic support
18:55:06.091: ---------------------------------
18:55:06.091: Loaded Modules:
18:55:06.091: win-wasapi.dll
18:55:06.091: win-mf.dll
18:55:06.091: win-dshow.dll
18:55:06.091: win-decklink.dll
18:55:06.092: win-capture.dll
18:55:06.092: vlc-video.dll
18:55:06.092: text-freetype2.dll
18:55:06.092: rtmp-services.dll
18:55:06.092: obs-x264.dll
18:55:06.092: obs-vst.dll
18:55:06.092: obs-transitions.dll
18:55:06.092: obs-text.dll
18:55:06.092: obs-qsv11.dll
18:55:06.092: obs-outputs.dll
18:55:06.092: obs-filters.dll
18:55:06.092: obs-ffmpeg.dll
18:55:06.092: obs-browser.dll
18:55:06.092: image-source.dll
18:55:06.092: frontend-tools.dll
18:55:06.092: enc-amf.dll
18:55:06.092: coreaudio-encoder.dll
18:55:06.092: ---------------------------------
18:55:06.092: ==== Startup complete ===============================================
18:55:06.095: All scene data cleared
18:55:06.095: ------------------------------------------------
18:55:06.134: WASAPI: Device 'Luidsprekers (Logitech G430 Gaming Headset)' initialized
18:55:06.146: WASAPI: Device 'Microfoon (USB Audio CODEC )' initialized
18:55:06.193: ---------------------------------
18:55:06.193: [DShow Device: 'C920'] settings updated:
18:55:06.193: video device: Logitech HD Pro Webcam C920
18:55:06.193: video path: \\?\usb#vid_046d&pid_082d&mi_00#6&9b48f33&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
18:55:06.193: resolution: 1920x1080
18:55:06.193: fps: 30.00 (interval: 333333)
18:55:06.193: format: I420
18:55:06.193: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
18:55:06.304: warning: Stream #0: not enough frames to estimate rate; consider increasing probesize
18:55:06.745: Switched to scene 'Scherm'
18:55:06.750: ------------------------------------------------
18:55:06.750: Loaded scenes:
18:55:06.750: - scene 'Scène':
18:55:06.750: - scene '1. Startscherm':
18:55:06.750: - source: 'NoCp[yRight Sound' (browser_source)
18:55:06.750: - source: 'Start overly' (image_source)
18:55:06.750: - scene '2. Game':
18:55:06.750: - source: 'IIyama' (monitor_capture)
18:55:06.750: - source: 'Gamecapture' (game_capture)
18:55:06.750: - source: 'Overlay' (image_source)
18:55:06.750: - source: 'Tipeeestream Game ' (browser_source)
18:55:06.750: - source: 'Subcounter' (browser_source)
18:55:06.750: - filter: 'Bijsnijden/Aanvullen' (crop_filter)
18:55:06.750: - filter: 'Chroma Key' (chroma_key_filter)
18:55:06.750: - source: 'C920' (dshow_input)
18:55:06.750: - filter: 'Chroma Key Met daklraam openm' (chroma_key_filter)
18:55:06.750: - filter: 'Chroma KeyDonker groen links onder' (chroma_key_filter)
18:55:06.750: - scene '3. Interface':
18:55:06.750: - scene 'Scherm':
18:55:06.756: - source: 'IIyama' (monitor_capture)
18:55:06.756: - source: 'Tipeeestream Game ' (browser_source)
18:55:06.756: - source: 'C920' (dshow_input)
18:55:06.756: - filter: 'Bijsnijden/Aanvullen' (crop_filter)
18:55:06.756: - filter: 'Chroma Key' (chroma_key_filter)
18:55:06.756: - filter: 'Chroma Key Met daklraam openm' (chroma_key_filter)
18:55:06.756: - filter: 'Chroma KeyDonker groen links onder' (chroma_key_filter)
18:55:06.756: - source: 'Subcounter' (browser_source)
18:55:06.756: - source: 'Subs in teks' (text_gdiplus)
18:55:06.756: ------------------------------------------------
18:55:44.571: User added filter 'extre' (chroma_key_filter) to source 'C920'
18:59:15.225: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
19:02:59.089: User switched to scene '2. Game'
19:03:16.227: [game-capture: 'Gamecapture'] attempting to hook fullscreen process: eurotrucks2.exe
19:03:16.230: [game-capture: 'Gamecapture'] using helper (compatibility hook)
19:03:16.231: [game-capture: 'Gamecapture'] hook not loaded yet, retrying..
19:03:19.243: [game-capture: 'Gamecapture'] attempting to hook fullscreen process: eurotrucks2.exe
19:03:19.252: [game-capture: 'Gamecapture'] Hooked DXGI
19:03:19.294: [game-capture: 'Gamecapture'] d3d9 shared texture capture successful
19:03:19.310: [game-capture: 'Gamecapture'] shared texture capture successful
19:03:46.910: [game-capture: 'Gamecapture'] capture window no longer exists, terminating capture
19:03:46.910: [game-capture: 'Gamecapture'] capture stopped
19:03:50.204: ---------------------------------
19:03:50.204: [NVENC encoder: 'streaming_h264'] settings:
19:03:50.204: rate_control: CBR
19:03:50.204: bitrate: 4000
19:03:50.204: cqp: 0
19:03:50.204: keyint: 120
19:03:50.204: preset: default
19:03:50.204: profile: main
19:03:50.204: level: auto
19:03:50.204: width: 1920
19:03:50.204: height: 1080
19:03:50.204: 2-pass: true
19:03:50.204: b-frames: 2
19:03:50.204: GPU: 0
19:03:50.204:
19:03:50.389: ---------------------------------
19:03:50.390: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
19:03:50.390:
19:03:50.391: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://a.rtmp.youtube.com/live2...
19:03:50.405: [rtmp stream: 'adv_stream'] Interface: Intel(R) Ethernet Connection (2) I219-V (ethernet, 1000 mbps)
19:03:50.669: [rtmp stream: 'adv_stream'] Connection to rtmp://a.rtmp.youtube.com/live2 successful
19:03:50.671: ==== Streaming Start ===============================================
19:04:05.027: [game-capture: 'Gamecapture'] attempting to hook fullscreen process: eurotrucks2.exe
19:04:05.030: [game-capture: 'Gamecapture'] using helper (compatibility hook)
19:04:05.030: [game-capture: 'Gamecapture'] hook not loaded yet, retrying..
19:04:08.043: [game-capture: 'Gamecapture'] attempting to hook fullscreen process: eurotrucks2.exe
19:04:08.052: [game-capture: 'Gamecapture'] Hooked DXGI
19:04:08.092: [game-capture: 'Gamecapture'] d3d9 shared texture capture successful
19:04:08.094: [game-capture: 'Gamecapture'] shared texture capture successful
19:19:50.914: User switched to scene 'Scherm'
19:19:51.244: [game-capture: 'Gamecapture'] capture stopped
19:23:20.087: User switched to scene '1. Startscherm'
19:23:20.514: User switched to scene '2. Game'
19:23:23.527: [game-capture: 'Gamecapture'] attempting to hook fullscreen process: eurotrucks2.exe
19:23:23.543: [game-capture: 'Gamecapture'] shared texture capture successful
20:01:51.799: User switched to scene 'Scherm'
20:01:51.810: [game-capture: 'Gamecapture'] capture stopped
20:01:52.262: User switched to scene '3. Interface'
20:01:53.707: User switched to scene '2. Game'
20:01:59.743: [game-capture: 'Gamecapture'] attempting to hook fullscreen process: eurotrucks2.exe
20:01:59.760: [game-capture: 'Gamecapture'] shared texture capture successful
20:02:08.064: User added source 'WC' (text_gdiplus) to scene '2. Game'
20:21:30.802: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
20:30:55.839: [rtmp stream: 'adv_stream'] User stopped the stream
20:30:55.839: Output 'adv_stream': stopping
20:30:55.839: Output 'adv_stream': Total frames output: 313492
20:30:55.839: Output 'adv_stream': Total drawn frames: 184634 (313527 attempted)
20:30:55.839: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 128893 (41.1%)
20:30:55.842: ==== Streaming Stop ================================================
20:30:55.892: warning: 2 frames left in the queue on closing
20:31:03.577: [game-capture: 'Gamecapture'] capture window no longer exists, terminating capture
20:31:03.577: [game-capture: 'Gamecapture'] capture stopped
20:35:08.893: ==== Shutting down ==================================================
20:35:08.897: Switched to scene '(null)'
20:35:08.995: WASAPI: Device 'Luidsprekers (Logitech G430 Gaming Headset)' Terminated
20:35:09.000: WASAPI: Device 'Microfoon (USB Audio CODEC )' Terminated
20:35:09.001: All scene data cleared
20:35:09.001: ------------------------------------------------
20:35:09.050: Freeing OBS context data
20:35:09.079: [Scripting] Total detached callbacks: 0
20:35:09.104: == Profiler Results =============================
