Question / Help Help increasing quality!
wuhndur
I cant seem to get better quality than I have. Ive tried higher bitrates, 60fps, and lower presets. Nothing seems to be improving my quality. Anyone have any tips? Also I notice it says there is a hook conflict which I dont understand. it said that when I first started streaming so I turned of the steam overlay and fps counter and it fixed that. Now again a couple says later its saying hook conflict and I havent changed anything.
PC Specs : http://pcpartpicker.com/user/wuhndur/saved/HnPNnQ
OBS Logs : https://gist.github.com/407e156698b3fca3e63e
Internet Speeds : http://www.speedtest.net/my-result/4444291573
Past Broadcast : http://www.twitch.tv/wuhntv/b/670975601
For streaming, you're probably not going to be able to get any better. 60fps vs 30fps will actually cause a quality drop while streaming since you are trying to fit twice as many frames into the same bitrate.
What would be a good bitrate for 60fps?
