Question / Help Help for stream configuration
downscale to 640x360 (the lowest downscale you can go) and set fps to 30fps. set bitrate and buffer to 500.
if that even works which it will probably be pretty bad quality.
your PC is old and even with those settings it might lag your game or saturate your upload speed which will give you trouble in game.
best recommendations: upgrade your PC to an i5 at minimum and internet to have at least 3-5Mb/s upload speed
