Heavy audio distortion when recording bass guitar for Youtube videos
Fuzzmaster
Ive been trying to record a video of me playing bass guitar, but all the recordings have heavy clipping. I know the input isnt clipping on my audio capture source as the input is below clipping levels. I tested my hardware on my DAW reaper and the audio comes out just fine with no distortion, so it isnt the hardware. My sources audio capture properties are set to the correct hardware, so Im at a loss. I’d appreciate it if someone could help me find a solution.
Make sure all of your devices are configured correctly in Windows with Spacial Sound & all enhancements disabled.
Pick a Sampling Rate too & set everything the same.
11:42:08.113: audio settings reset:
11:42:08.113: samples per sec: 48000
11:42:08.113: speakers: 2
11:42:09.350: WASAPI: Device 'Microphone (HD Pro Webcam C920)' [16000 Hz] initialized
11:42:09.353: ---------------------------------
11:42:09.353: [DShow Device: 'Device camera'] settings updated:
11:42:09.353: video device: HD Pro Webcam C920
11:42:09.353: video path: \\?\usb#vid_046d&pid_08e5&mi_00#7&2d6bcaff&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
11:42:09.353: resolution: 1920x1080
11:42:09.353: flip: 0
11:42:09.353: fps: 30.00 (interval: 333333)
11:42:09.353: format: MJPEG
11:42:09.353: buffering: disabled
11:42:09.370: WASAPI: Device 'Microphone (HD Pro Webcam C920)' [16000 Hz] initialized
11:42:09.380: WASAPI: Device 'Speakers (AudioBox USB 96)' [44100 Hz] initialized
11:42:09.395: adding 64 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Audio Input Capture)
You mean set the sources the same as the settings? im new to obs
The only place I can find how to adjust the sample for these devices is in the settings, but I dont know where to adjust these individually in the program.
