Hi Everyone,
I have a bit of frame drop issue here. I was trying out own3d to see the difference in quality between own3d.tv and twitch.tv. Streaming to own3d.tv with Xsplit was fine, but I perfer obs since it allows me to give a better quality stream. The problem for some odd reason in obs when streaming to own3d.tv, I tend to have hella lot more frame drops compared to xsplit. I normally wouldn't have this problem with Twitch.tv How do I fix this? Am I doing something wrong?
Edit: Nevermind, figured it out. I increased my buffer size 8192 and solved the problem
Open Broadcaster Software v0.432a - 32bit (´・ω・`)
CPU Name: AMD Phenom(tm) II X6 1045T Processor
CPU Speed: 2700MHz
Physical Memory: 4083MB Total, 2565MB Free
stepping id: 0, model 10, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 6, total cores 6
Adapter 1
Video Adapter: NVIDIA GeForce GT 430
Video Adapeter Dedicated Video Memory: 1025966080
Video Adapeter Shared System Memory: 1872353280
Send Buffer Size: 4096
Base resolution: 1280x720
Output resolution: 1280x720
Loading up D3D10...
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 128
chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, fps: 15-60.0002, fourCC: 'YV12'
Video Encoding: x264
fps: 30
width: 1280, height: 720
quality: 10
preset: medium
i444: no
max bitrate: 1400
buffer size: 1400
Total frames rendered: 296, number of frames that lagged: 5 (1.69%) (it's okay for some frames to lag)
Number of b-frames dropped: 46, Number of p-frames dropped: 0
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
quality: 10
preset: medium
i444: no
max bitrate: 1400
buffer size: 1400
Total frames rendered: 34320, number of frames that lagged: 18 (0.05%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
quality: 10
preset: medium
i444: no
max bitrate: 1400
buffer size: 1400
Total frames rendered: 1884, number of frames that lagged: 9 (0.48%) (it's okay for some frames to lag)
Number of b-frames dropped: 305, Number of p-frames dropped: 0
Profiler results:
frame - [100%] [avg time: 8.145 ms] [avg calls per frame: 1] [children: 90.6%] [unaccounted: 9.44%]
| scene->Preprocess - [15.9%] [avg time: 1.296 ms] [avg calls per frame: 1]
| video encoding and uploading - [74.6%] [avg time: 6.08 ms] [avg calls per frame: 1] [children: 28.7%] [unaccounted: 45.9%]
| | CopyResource - [0.27%] [avg time: 0.022 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.282%] [avg time: 0.023 ms] [avg calls per frame: 0]
| | call to encoder - [28.2%] [avg time: 2.294 ms] [avg calls per frame: 0]
