Question / Help Frame Skipping please help
billyboy
It was fine before, it's just started to happen 3-4 days ago.
Doesn't matter what resolution, fps, buffer size, etc. I set, it will run perfectly for about 10-20 seconds, and then freeze up for about 2-3 seconds.. then go back to normal for another 10 seconds and it just repeats. Audio doesn't lag, just the picture.
You can understand the issue from that video more clearly http://www.twitch.tv/billyxboy/v/16769583
Specs:
i7 4700MQ
GTX 870M
8GB Ram
Windows 10
My obs bitrate is: 1500kb/s
My obs log: https://gist.github.com/7f65b474e24f7826d603
My internet speed:
