Question / Help First time using OBS / Settings Help
TheyCallMeLoaf
Rig
i4790k (currently not overclocked)
Gigabyte GTX 970 Gaming
Sony PJ260V Camcorder (being used instead of webcam)
Avermedia LiveGamer HD
ASUS vg248qe
AT2020 Microphone
16GB Ram
Speedtest
DL: 68mbps
UP: 4.25mbps
Alright, so above I listed some of the components to my computer and the most recent speed test. I briefly ran OBS last night and did a test recording and it was really grainy (even after the first few seconds of pixel burst) So I am going to have to spend some time setting things up correctly. However, how to do that, well, I have no idea.
These are my questions
For Recording (Not streaming) in 720p @ 60fps what should my settings be at?
For Streaming... what should I be aiming for (id like to record the streaming as well) and what settings should I have for that?
For local recording your settings should probably look like this - https://obsproject.com/forum/resources/how-to-make-high-quality-local-recordings.16/ - I record at 1080p60 on the ultrafast preset and crf=18, then re-encode with Handbrake later with more compression to get my desired frame rate/resolution.
For streaming at 720p60 your CPU should be able to handle most things on the fast preset, though if you aren't partnered you might consider 720p30 at 2000-2500 Kbps to minimize playback buffering for your viewers. At 720p30 the medium preset shouldn't cause any problems unless you're playing, I don't know, Assassin's Creed Unity or something, which is supposed to be incredibly demanding and thus makes streaming much more difficult.
