Final result very laggy and low quality
SirChat
When im recording everything looks very clean and the frame rates are good, but when i watch the final video after the recording it looks very bad and looks like it skipps a few frames or something. i also checked my cpu and gpu while recording and those stats look very good. do i need to set my settings lower?
cpu: ryzen 7 2700x
gpu: nvidia gtx 1660 super
log file: https://obsproject.com/logs/M0wEn7istEHipMOR
Use VLC to play back your videos. Do not use the default windows video player -- it does not handle 30+fps video properly.
Don't use non-standard framerates. 60fps or 30fps, nothing in between.
Stick with CQP for recording. The lower the value, the better the quality.
You're also running 2 monitors at different refresh rates, which means you should definitely update windows at least to version 2004, which includes fixes to mixed monitor GPU acceleration.
