File (mkv) didn´t save after recording, stopping recording was taking way too long so I clicked it again
Xavier_1
I have this important recording I was doing and after i finish i clicked on stop recording, it was taking forever on stopping recording so i clicked it againg just out of curiosity and it stopped, i checked my folder where the videos are saved but there was only a video with the first 3 minutes, i was recording for over an hour :( Is there any way i can recover this file? I would really apreciate it. And I was saving it in mkv btw not mp4.
18:05:04.949: CPU Name: Intel(R) Core(TM) i5-5300U CPU @ 2.30GHz
18:05:04.949: CPU Speed: 2295MHz
18:05:04.950: Physical Cores: 2, Logical Cores: 4
18:05:04.950: Physical Memory: 8064MB Total, 1383MB Free
18:05:04.950: Windows Version: 10.0 Build 19043 (release: 2009; revision: 1645; 64-bit)
18:05:04.950: Running as administrator: false
18:05:04.950: Aero is Enabled (Aero is always on for windows 8 and above)
18:05:05.007: Windows 10 Gaming Features:
18:05:05.007: Game Bar: On
18:05:05.008: Game DVR: On
18:05:05.008: Game DVR Background Recording: Off
18:05:05.707: Sec. Software Status:
18:05:06.669: Antivirus de Microsoft Defender: enabled (AV)
18:05:06.677: Firewall de Windows: enabled (FW)
18:05:07.099: Current Date/Time: 2022-05-12, 18:05:07
18:05:07.099: Browser Hardware Acceleration: true
18:05:07.099: Hide OBS windows from screen capture: false
18:05:07.099: Qt Version: 5.15.2 (runtime), 5.15.2 (compiled)
18:05:07.099: Portable mode: false
18:05:48.359: OBS 27.2.4 (64-bit, windows)
18:05:48.359: ---------------------------------
18:05:48.458: ---------------------------------
18:05:48.458: audio settings reset:
18:05:48.458: samples per sec: 48000
18:05:48.458: speakers: 2
18:05:50.615: ---------------------------------
18:05:50.615: Initializing D3D11...
18:05:50.615: Available Video Adapters:
18:05:50.633: Adapter 0: Intel(R) HD Graphics 5500
18:05:50.633: Dedicated VRAM: 134217728
18:05:50.633: Shared VRAM: 4228001792
18:05:50.633: PCI ID: 8086:1616
18:05:50.651: Driver Version: 20.19.15.4531
18:05:50.662: output 0:
18:05:50.662: name=
18:05:50.662: pos={0, 0}
18:05:50.662: size={1920, 1080}
18:05:50.662: attached=true
18:05:50.662: refresh=60
18:05:50.662: space=RGB_FULL_G22_NONE_P709
18:05:50.662: sdr_white_nits=80
18:05:50.662: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
18:05:50.940: Loading up D3D11 on adapter Intel(R) HD Graphics 5500 (0)
18:05:51.232: D3D11 loaded successfully, feature level used: b000
18:05:51.233: DXGI increase maximum frame latency success
18:06:25.390: ---------------------------------
18:06:25.390: video settings reset:
18:06:25.390: base resolution: 1920x1080
18:06:25.390: output resolution: 1280x720
18:06:25.390: downscale filter: Bicubic
18:06:25.390: fps: 30/1
18:06:25.390: format: NV12
18:06:25.390: YUV mode: 709/Partial
18:06:25.391: NV12 texture support not available
18:06:25.818: Audio monitoring device:
18:06:25.818: name: Por defecto
18:06:25.818: id: default
18:06:25.825: ---------------------------------
18:06:26.468: No AJA devices found, skipping loading AJA UI plugin
18:06:26.468: Failed to initialize module 'aja-output-ui.dll'
18:06:27.199: No AJA devices found, skipping loading AJA plugin
18:06:27.200: Failed to initialize module 'aja.dll'
18:06:28.809: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
18:06:30.257: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:06:31.074: Failed to load 'en-US' text for module: 'decklink-captions.dll'
18:06:31.385: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
18:06:38.803: [AMF] Unable to load 'amfrt64.dll', error code 126.
18:06:38.847: [AMF] AMF Test failed due to one or more errors.
18:06:38.847: Failed to initialize module 'enc-amf.dll'
18:06:44.404: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
18:06:45.127: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
18:06:46.539: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
18:06:49.209: [obs-browser]: Version 2.17.13
18:06:49.209: [obs-browser]: CEF Version 95.0.0-MediaHandler.2467+g8092a57+chromium-95.0.4638.69
18:06:52.120: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
18:06:56.988: [vlc-video]: VLC 3.0.16 Vetinari found, VLC video source enabled
18:07:06.561: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
18:07:06.588: No blackmagic support
18:07:08.619: ---------------------------------
18:07:08.619: Loaded Modules:
18:07:08.619: win-wasapi.dll
18:07:08.619: win-mf.dll
18:07:08.619: win-dshow.dll
18:07:08.619: win-decklink.dll
18:07:08.619: win-capture.dll
18:07:08.620: vlc-video.dll
18:07:08.620: text-freetype2.dll
18:07:08.620: rtmp-services.dll
18:07:08.620: obs-x264.dll
18:07:08.620: obs-vst.dll
18:07:08.620: obs-transitions.dll
18:07:08.620: obs-text.dll
18:07:08.620: obs-qsv11.dll
18:07:08.620: obs-outputs.dll
18:07:08.620: obs-filters.dll
18:07:08.620: obs-ffmpeg.dll
18:07:08.620: obs-browser.dll
18:07:08.620: image-source.dll
18:07:08.620: frontend-tools.dll
18:07:08.620: decklink-ouput-ui.dll
18:07:08.620: decklink-captions.dll
18:07:08.621: coreaudio-encoder.dll
18:07:08.621: ---------------------------------
18:07:08.640: ==== Startup complete ===============================================
18:07:16.178: All scene data cleared
18:07:16.178: ------------------------------------------------
18:07:16.722: [win-wasapi: 'Audio del escritorio'] update settings:
18:07:16.722: device id: default
18:07:16.722: use device timing: 1
18:07:16.754: [Loaded global audio device]: 'Audio del escritorio'
18:07:16.756: [win-wasapi: 'Mic/Aux'] update settings:
18:07:16.756: device id: default
18:07:16.756: use device timing: 0
18:07:16.757: [Loaded global audio device]: 'Mic/Aux'
18:07:16.760: [duplicator-monitor-capture: 'Captura de pantalla'] update settings:
18:07:16.760: display: 1 (1920x1080)
18:07:16.760: cursor: true
18:07:16.760: method: DXGI
18:07:16.769: Switched to scene 'Escena'
18:07:16.769: ------------------------------------------------
18:07:16.769: Loaded scenes:
18:07:16.769: - scene 'Escena':
18:07:16.770: - source: 'Captura de pantalla' (monitor_capture)
18:07:16.770: ------------------------------------------------
18:07:19.701: WASAPI: Device 'Altavoces / Auriculares (Realtek Audio)' [48000 Hz] initialized
18:07:19.770: adding 234 milliseconds of audio buffering, total audio buffering is now 234 milliseconds (source: Audio del escritorio)
18:07:19.770:
18:07:27.330: WASAPI: Device 'Varios micrófonos (Realtek Audio)' [48000 Hz] initialized
18:07:32.484: ---------------------------------
18:07:32.484: [x264 encoder: 'streaming_h264'] preset: veryfast
18:07:32.526: [x264 encoder: 'streaming_h264'] settings:
18:07:32.526: rate_control: CBR
18:07:32.526: bitrate: 2500
18:07:32.526: buffer size: 2500
18:07:32.526: crf: 23
18:07:32.526: fps_num: 30
18:07:32.526: fps_den: 1
18:07:32.526: width: 1280
18:07:32.526: height: 720
18:07:32.526: keyint: 250
18:07:32.526:
18:07:32.624: ---------------------------------
18:07:32.628: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
18:07:32.628:
18:07:33.231: ==== Recording Start ===============================================
18:07:33.231: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/Serna/Videos/2022-05-12 18-07-32.mkv'...
19:34:03.483: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/Serna/Videos/2022-05-12 18-07-32.mkv' stopped
19:34:03.483: Output 'adv_file_output': stopping
19:34:03.483: Output 'adv_file_output': Total frames output: 5373
19:34:03.483: Output 'adv_file_output': Total drawn frames: 84503 (155708 attempted)
19:34:03.483: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 71205 (45.7%)
19:34:03.497: ==== Recording Stop ================================================
19:34:03.532: Video stopped, number of skipped frames due to encoding lag: 5344/5395 (99.1%)
16:22:06.925: Max audio buffering reached!
16:22:06.925: adding 725 milliseconds of audio buffering, total audio buffering is now 960 milliseconds (source: Audio del escritorio)
16:22:06.925:
16:22:06.925: Source Audio del escritorio audio is lagging (over by 56427074.50 ms) at max audio buffering. Restarting source audio.
00:49:07.552: ==== Shutting down ==================================================
00:49:10.397: WASAPI: Device 'Altavoces / Auriculares (Realtek Audio)' Terminated
Your video was saved in this folder:
Anyways, you have a bigger issue with 46% of rendering lag and 99% of skiped frames, wich means there's nothing recorded.
You can try updating the video driver directly from Intel's site and see if this helps.
And please take a look at the troubleshooting guides:
I know it was saved on that folder, but that file (2022-05-12 18-07-32) is only 3 minutes long and I recorded for over 1 hour, I think i must have interrupted the saving process but is there anything I can do? I know my pc is a potato but it is what i have.
That's a sign that you severely overloaded your computer with the recording, so the video encoder within OBS had to skip many frames, and at the end it wasn't able to catch up at all, so starting from some point in time, nothing at all was written to the video file. This is lost.
Use Tools->Auto Configuration Wizard to create a configuration tailored to your hardware.
