You appear to be streaming over a wireless connection. While this can be OK, keep in mind that interference from other radio sources or obstacles can cause your connection to momentarily stall, resulting in dropped frames or disconnects. A wired connection is strongly recommended for a reliable stream.
Possible slow server
The server you are streaming to (rtmp://live-lhr.twitch.tv/app) took 838 ms to connect. This may mean your connection or the server is slow, or the server is far away from you. If you are using twitch.tv, you may want to try using JTVPing to find an optimal server.
