Josh Lemmon
Hello,
I've spent the best part of a week trying to get OBS to work as it used to. I was able to comfortably record at 1080p 60fps about 4 months ago, but since I've stated recording again I seem to keep getting the dreaded "encoding overload" message at the bottom of OBS..
I'm using an AMD Ryzen 7, the CPU usage on the task manager is usually around 30%. My GPU usage does go up very high though (it's an AMD R9 200/ HD 7900)
log file
Any advice would be greatly appreciated!
log file
