Question / Help Elgato video/sound problem
konkondas
I have a problem with obs, that I never had before...
In the start of the video, it works great, but after 1 minute, video goes like 4 seconds slower than the sound from the ps3 and my microphone sound.
It happened after I made a super mario video on the wii (I use a universal component cable for ps3, xbox and wii).
I have been playing around with the settings... But the sound always goes out of sync.
I am using some settings that are supposed to make a skype call synced while using elgato.
Heres the settings I use:
Encoding:
Encoder=x264
Use CBR=Yes
Enable CBR padding=Yes
Max bitrate=10000
Use custom buffer size=No
Codec=AAC
Format=48Hz
Bitrate=128
Channel=Stereo.
Broadcast settings:
File output only.
Replay buffer length=1
Video:
Video Adapter=ATI Mobility Radeon HD 5650
Base resolution=Custom: 1280x720
Resolution downscale=1.50
Filter=Bilinear
FPS=30
Disable aero=Yes
Audio:
All at defaults.
Hotkeys:
Not so important.
Advanced:
Use multithreaded optimizations=Yes
Procces priority class= Normal/Above Normal
Scene buffering time=700 (has been trying 2000)
Disable encoding while previewing=No
Allow other modifiers on hotkeys=Yes
x264 CPU preset=Superfast
Encoding profile=Main
Keyframe Interval=2
Use CFR=Yes
Custom x264 Encoder settings=No
Encode in full range=No
Allow 61-120 FPS entry in video settings=No
Force desktop audio to use timestamps as base for audio time=No
Global audio sync offset=1500
Use mic QPC timestamps=No
The rest(network) is default.
Please post a log.
Also, open the properties of the Elgato capture device, check buffering and set the buffer time to 1.
Let me know if that helps.
