Question / Help Elgato/PS4 Audio/Visual issue
Minkaro
(This is a separate issue to the last one I posted about, just to let people know that I'm not posting the same thread twice).
OK, I've just recorded some gameplay footage using the Elgato and OBS. The problem with that footage is that there is no game audio. So I went into the properties of the Elgato in OBS, and saw that I had my audio input device set to "use device audio." Now, I've seen in other threads that can sometimes cause issues, so I switched it to the option that says "Elgato Game Capture HD" This resulted in a black screen on OBS...and still no game audio.
Another bit of information that might make a difference is that I had my headphones plugged into the PS4 controller when I was recording, so I could hear the game audio (with another set of headphones plugged into the computer, just to avoid any echo). Would this make any difference?
If you need any sort of screenshot or log file, let me know and I'll get those.
Edit: Oh, might there be something I need to do in the Elgato software? Some option in that that I've got set to the wrong thing?
