Elgato HD60s+ Keeps dropping audio on OBS
KingK6977
Please help, this is driving me mad! I have recently purchased an Elgato HD60s+ to stream from Xbox One to PC. When I first start up OBS the audio is crystal clear and working, however, after a couple of minutes (sometimes seconds) the game capture audio simply stops, after a few more seconds it then starts to blip on and off in a consistent pattern. I fell at this point i have looked at/adjusted just about every setting, has anyone else had this issue? Log attached. Youtube video link of it happening https://youtu.be/hb3k1CyA7xo
Is it just OBS, if you run the capture in the elgato 4K capture application does the audio drop there at all?
Just had a quick glimpse at your log, in obs you have audio set to default device, have you tried setting the custom audio and choosing wave out in your capture device / scene?
Realised that was your audio monitoring at second glance, is worth checking the custom audio for device though if you haven’t already :)
