logfile needed. copy the link from the help menu and paste the link here.Hey, I have problems with my Elgato HD 60 sound in OBS. It works fine in the Elgato software. But on OBS I have sound distortion/hang ups/noise.
I am trying to record different consoles, Wii/PS4 for example. Recording a PC game works fine.
ok, did you verify that windows recording and playback devices were usings 48000Hz for audio?
There is probably an updated elgato driver AND firmware avail. the newest version forces OBS to 1ms buffer, yours doesn't so I would wonder if it is the newest. give that a try. you might have to uninstall the older elgato drivers first.Microphone and speaker are 48000 Hz
my English is not the best.
Now that its showing the 1ms buffer thing, it should be newest drivers.Sound of the elgato wasnt selected (shown in the logs) so I had Kati do that. It then shows:
19:22:04: audio device: Elgato Game Capture HD,
19:22:04: audio device id {39F50F4C-99E1-464A-B6F9-D605B4FB5918},
19:22:04: audio time offset 0,
19:22:04: Elgato Game Capture: force buffering with 1 msec
Unfortunately not showing any Hz setting. She also removed and readded the device in all scenes. As far as I know its also a new PC, so it should have the latest drivers, but that is worth checking.
Soundproblem in audio form: http://www.mediafire.com/listen/ad4w1h36cf4osmq/video-1445265607.mp4.mp3
I am running out of ideas a bit atm.
Oh and complete log: https://gist.github.com/anonymous/7d6e1ce9f12ac3113134
So far no luck, the really strange thing is that the Elgato works fine in its own Software and in XSplit as well :/
