Emergamer02
Let me make it clear that I am using the original Elgato Game Capture HD and not the HD60. I run Windows 8.1 and the captures in question were done with a Wii through a Component Cable and its adapter. I am recording to a video file, not broadcasting online.
When I try to record 720p60fps footage, I experience slightly frequent stuttering. It especially happens when there is a flashy effect, like a trick in Mario Kart.
How would I fix it to get smooth 60fps footage?
Here is the log file:
08:39:43: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
08:39:43: -------------------------------
08:39:43: CPU Name: Intel(R) Core(TM) i7-4700HQ CPU @ 2.40GHz
08:39:43: CPU Speed: 2394MHz
08:39:43: Physical Memory: 4095MB Total, 4095MB Free
08:39:43: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
08:39:43: monitor 1: pos={0, 0}, size={1600, 900}
08:39:43: Windows Version: 6.2 Build 9200
08:39:43: Aero is Enabled
08:39:43: OBS Modules:
08:39:43: Base Address Module
08:39:43: 00830000 OBS.exe
08:39:43: 5A980000 OBSApi.dll
08:39:43: 5A720000 DShowPlugin.dll
08:39:43: 5A6F0000 GraphicsCapture.dll
08:39:43: 5A6C0000 NoiseGate.dll
08:39:43: 5A6A0000 PSVPlugin.dll
08:39:43: 5A680000 scenesw.dll
08:39:43: ------------------------------------------
08:39:43: Adapter 1
08:39:43: Video Adapter: NVIDIA GeForce GTX 765M
08:39:43: Video Adapter Dedicated Video Memory: 2082271232
08:39:43: Video Adapter Shared System Memory: 2147676160
08:39:43: Video Adapter Output 1: pos={0, 0}, size={1600, 900}, attached=true
08:39:43: =====Stream Start: 2015-07-08, 08:39:43===============================================
08:39:43: Multithreaded optimizations: On
08:39:43: Base resolution: 1280x720
08:39:43: Output resolution: 1280x720
08:39:43: Loading up D3D10 on NVIDIA GeForce GTX 765M (Adapter 1)...
08:39:43: Audio Format: 48000 Hz
08:39:43: Audio Channels: 2 Ch
08:39:43: Playback device Default
08:39:43: Using desktop audio input: Speakers (Realtek High Definition Audio)
08:39:43: Global Audio time adjust: 0
08:39:43: Audio Encoding: AAC
08:39:43: bitrate: 160
08:39:44: ------------------------------------------
08:39:44: device: Elgato Game Capture HD,
08:39:44: device id {39F50F4C-99E1-464A-B6F9-D605B4FB5918},
08:39:44: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 166666-166666
08:39:44: use buffering: true - 0, fourCC: 'UYVY'
08:39:44:
08:39:44: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
08:39:44: Elgato Game Capture: force buffering with 1 msec
08:39:50: Using directshow input
08:39:50: Scene buffering time set to 700
08:39:50: ------------------------------------------
08:39:50: Video Encoding: x264
08:39:50: fps: 60
08:39:50: width: 1280, height: 720
08:39:50: preset: fast
08:39:50: profile: main
08:39:50: keyint: 120
08:39:50: CBR: yes
08:39:50: CFR: yes
08:39:50: max bitrate: 6000
08:39:50: buffer size: 6000
08:41:51: FlushBufferedVideo: Flushing 1 packets over 0 ms
08:41:51: Total frames encoded: 7246, total frames duplicated: 10 (0.14%)
08:41:51: Total frames rendered: 7294, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
08:41:55:
08:41:55: Profiler time results:
08:41:55:
08:41:55: ==============================================================
08:41:55: video thread frame - [100%] [avg time: 1.058 ms] [children: 42.5%] [unaccounted: 57.5%]
08:41:55: | scene->Preprocess - [34.6%] [avg time: 0.366 ms]
08:41:55: | GPU download and conversion - [7.94%] [avg time: 0.084 ms] [children: 6.05%] [unaccounted: 1.89%]
08:41:55: | | flush - [3.5%] [avg time: 0.037 ms]
08:41:55: | | CopyResource - [2.27%] [avg time: 0.024 ms]
08:41:55: | | conversion to 4:2:0 - [0.284%] [avg time: 0.003 ms]
08:41:55: Convert444Threads - [100%] [avg time: 0.401 ms] [children: 98.8%] [unaccounted: 1.25%]
08:41:55: | Convert444toNV12 - [98.8%] [avg time: 0.396 ms]
08:41:55: encoder thread frame - [100%] [avg time: 0.881 ms] [children: 0.341%] [unaccounted: 99.7%]
08:41:55: | sending stuff out - [0.341%] [avg time: 0.003 ms]
08:41:55:
08:41:55:
08:41:55: Profiler CPU results:
08:41:55:
08:41:55: video thread frame - [cpu time: avg 0.374 ms, total 2734.38 ms] [avg calls per frame: 1]
08:41:55: | scene->Preprocess - [cpu time: avg 0.01 ms, total 78.125 ms] [avg calls per frame: 1]
08:41:55: | GPU download and conversion - [cpu time: avg 0.038 ms, total 281.25 ms] [avg calls per frame: 1]
08:41:55: | | flush - [cpu time: avg 0.019 ms, total 140.625 ms] [avg calls per frame: 1]
08:41:55: | | CopyResource - [cpu time: avg 0.006 ms, total 46.875 ms] [avg calls per frame: 1]
08:41:55: | | conversion to 4:2:0 - [cpu time: avg 0.004 ms, total 31.25 ms] [avg calls per frame: 1]
08:41:55: Convert444Threads - [cpu time: avg 0.67 ms, total 9718.75 ms] [avg calls per frame: 2]
08:41:55: | Convert444toNV12 - [cpu time: avg 0.667 ms, total 9671.88 ms] [avg calls per frame: 2]
08:41:55: encoder thread frame - [cpu time: avg 0.155 ms, total 1125 ms] [avg calls per frame: 1]
08:41:55: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
08:41:55:
08:41:55: =====Stream End: 2015-07-08, 08:41:55=================================================
Last game capture log:
2015-06-06, 17:47:03: we're booting up:
17:47:03: CaptureThread: attached to process javaw.exe
17:47:03: GL Present
17:47:03: DirectDraw capture: Windows 8 not supported yet
17:47:03: (half life scientist) everything.. seems to be in order
17:47:03: SwapBuffers(1342245901) Called
17:47:03: NV Capture available
17:47:03: FBO available
17:47:03: setting up gl data
17:47:03: share device: 819880080
17:47:03: share texture: 814495920
17:47:03: share device handle: 3810664990
17:47:03: share texture handle: 3811292690
17:47:03: DoGLGPUHook: success
17:47:03: wglSwapBuffers(1342245901) Called
17:47:11: stop requested, terminating gl capture
17:47:11: ---------------------- Cleared OpenGL Capture ----------------------
17:47:11: wglSwapBuffers(1342245901) Called
17:47:11: setting up gl data
17:47:11: SwapBuffers(1342245901) Called
17:47:11: new GL DC found (1627462354, was 1342245901), terminating gl capture
17:47:11: wglSwapBuffers(1627462354) Called
17:47:11: SwapBuffers(1627462354) Called
17:47:11: DirectDraw capture: Windows 8 not supported yet
17:47:42: new GL DC found (2248214589, was 1627462354), terminating gl capture
17:47:42: ---------------------- Cleared OpenGL Capture ----------------------
17:47:42: wglSwapBuffers(2248214589) Called
17:47:42: setting up gl data
17:47:42: SwapBuffers(2248214589) Called
17:47:44: DirectDraw capture: Windows 8 not supported yet
17:47:45: share device: 845798528
17:47:45: share texture: 814489200
17:47:45: share device handle: 3809621486
17:47:45: share texture handle: 3761757890
17:47:45: DoGLGPUHook: success
17:47:59: stop requested, terminating gl capture
17:47:59: ---------------------- Cleared OpenGL Capture ----------------------
17:47:59: wglSwapBuffers(2248214589) Called
17:47:59: setting up gl data
17:47:59: SwapBuffers(2248214589) Called
17:48:00: DirectDraw capture: Windows 8 not supported yet
17:48:00: new GL DC found (3305183836, was 2248214589), terminating gl capture
17:48:00: ---------------------- Cleared OpenGL Capture ----------------------
17:48:00: wglSwapBuffers(3305183836) Called
17:48:00: setting up gl data
17:48:00: SwapBuffers(3305183836) Called
17:48:04: DirectDraw capture: Windows 8 not supported yet
17:48:14: new GL DC found (83953697, was 3305183836), terminating gl capture
17:48:14: ---------------------- Cleared OpenGL Capture ----------------------
17:48:14: wglSwapBuffers(83953697) Called
17:48:14: setting up gl data
17:48:14: SwapBuffers(83953697) Called
17:48:16: DirectDraw capture: Windows 8 not supported yet
17:53:35: wglDeleteContext Called
17:53:35: ---------------------- Cleared OpenGL Capture ----------------------
