Michael RIll
So I used to stream regularly with no frame drop page or stuttering. I took a break and stopped streaming for a while. I came back and started streaming with the same settings and have been getting some frame drop page. Nothing huge as my light on OBS stays in the green the majority of the time, and it says about 0.50 to 1% frame drops while streaming. I was just curious if anyone has any ideas what could be causing this issue. I've tried all the different troubleshooting methods to try and fix the problem. Such as changing twitch servers, lowering my bit rate(even thou I shouldn't need to as you can see by my upload speed), lowering my resolution from 1600x900 down scaled to 720P to actual native 720P. No matter what I do I seem to be getting about a maximum 2% frame drop. It never goes in the yellow or red and is mostly in the green, but when I streamed back in the day I got 0 frame drops. Any help would be greatly appreciated!
Also here are my PC Specs:
CPU: Intel Core i7-4930K CPU @ 3.40Ghz 3.70Ghz
GPU: GeForce GTX 780 Ti Graphics card - 3 GB - GDDR5 SDRAM
Ram: 16.0GB
Operating System : Windows 8.1 64 Bit
Hard Drive: Seagate Barracuda 2TB
Ram: 16.0GB
