Question / Help CRL Browser - Works on 64-bit, not on 32-bit [Solved]
XSrcewGravityX
Hi,
I have a problem with the CRL Browser Plugin,
It works perfectly fine on the 64-bit version of OBS but on the 32-bit it shows in the plugins menu but i can't add a CRL Browser. Any idea about this one?? BTW: Im sure i got the 32-bit files in the 32-bit folder.
SOLUTION!
I know what the problem is..., this was my problem, i only downloaded the 64-bit version and not the 32-bit version of MS Visual C++ Run Times to 2013. So i tried downloading the 32-bit version and it worked. ;)
