Question / Help Crackling in Headphones, and Frame skipping while Streaming.
Jehoshua
Every time I hit Preview Stream/Record/Start Streaming, I get a crackling in my headphones. When I then move in the game, I get lag, or frame skips. When I analyze the log, It comes up as a hooked conflict, but I have no idea what's causing it. It was working fine the first few days I was streaming, after that, I had this issue.
Aside from all that, I appreciate what you're doing with this software, it's amazing.
I appreciate any advice or help you have to offer. Thank you!
No one is sure? Any idea how I can find the other hooking object? Is AMD CCC doing it some how?
On a side note, I'm not getting that issue if I go with monitor capture. But I am getting a huge drop in frames, vs using game capture.
