funnyman1120
I got this error today randomly, I haven't changed anything what so ever. I got Advanced Warfare, and was going to go stream it. So I opened OBS and got the error "Cannot Initialize Desktop sound, see log for more info".
Before just posting for help I googled it, found some tutorials that didn't work, went on these forums and most the time this problem has been associated with Kracken headsets? I don't have them. I have Turtle Beach x12's, but either way I tried using the suggested 64bit, which also didn't work.
10:18:44: CLR host plugin strings not found, dynamically loading 4 strings
10:18:44: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
10:18:44: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
10:18:44: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
10:18:44: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
10:18:44: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
10:18:44: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
10:18:44: CLRHost:: Could not find/load browser settings at location C:\Users\Cory\AppData\Roaming\OBS\pluginData\browser.json
10:18:44: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\Cory\AppData\Roaming\OBS\pluginData\browser.json'.
10:18:44: File name: 'C:\Users\Cory\AppData\Roaming\OBS\pluginData\browser.json'
10:18:44: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
10:18:44: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
10:18:44: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
10:18:44: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
10:18:44: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
10:18:44: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
10:18:45: Open Broadcaster Software v0.64b - 64bit ( ^ω^)
10:18:45: -------------------------------
10:18:45: CPU Name: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
10:18:45: CPU Speed: 3997MHz
10:18:45: Physical Memory: 8134MB Total, 2690MB Free
10:18:45: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
10:18:45: monitor 1: pos={0, 0}, size={1680, 1050}
10:18:45: Windows Version: 6.1 Build 7601 S
10:18:45: Aero is Enabled
10:18:45: OBS Modules:
10:18:45: Base Address Module
10:18:45: 000000003F370000 OBS.exe
10:18:45: 00000000EFF40000 OBSApi.dll
10:18:45: 00000000F1CA0000 CLRHostPlugin.dll
10:18:45: 00000000F0D20000 DShowPlugin.dll
10:18:45: 00000000F0CE0000 GraphicsCapture.dll
10:18:45: 00000000F0B60000 NoiseGate.dll
10:18:45: 00000000F0A60000 PSVPlugin.dll
10:18:45: ------------------------------------------
10:18:45: Adapter 1
10:18:45: Video Adapter: NVIDIA GeForce GTX 750 Ti
10:18:45: Video Adapter Dedicated Video Memory: 2070609920
10:18:45: Video Adapter Shared System Memory: 2147807232
10:18:45: Video Adapter Output 1: pos={0, 0}, size={1680, 1050}, attached=true
10:18:45: =====Stream Start: 2015-02-21, 10:18:45===============================================
10:18:45: Multithreaded optimizations: On
10:18:45: Base resolution: 1920x1080
10:18:45: Output resolution: 1920x1080
10:18:45: Loading up D3D10 on NVIDIA GeForce GTX 750 Ti (Adapter 1)...
10:18:45: Audio Format: 48000 Hz
10:18:45: Audio Channels: 2 Ch
10:18:45: Playback device {0.0.0.00000000}.{bd9cf15f-94e1-478b-9a01-d55023006807}
10:18:45: Using desktop audio input: Speakers (Realtek High Definition Audio)
10:18:45: Global Audio time adjust: 0
Warning -- MMDeviceAudioSource::Initialize(0): Could not initialize audio client, result = AUDCLNT_E_CPUUSAGE_EXCEEDED
Error: Cannot initialize desktop audio sound, more info in the log file.
10:18:45: Adapter 1
