Question / Help cam problem
Agh, I actually do have the webcam but I've neglected to actually take a look (as usual, ugh I'm sorry, I've just been so busy with the rewrite, and the fact that the rewrite will make the current device code obsolete).
I will stop neglecting this issue and attempt to take a look at it
Okay, I tried it with the problem webcam, HD-3000, exact one as in the original post. Now the brightness was quite low by default in its settings just as explained in the original post, but that was due to the lamp in the background and the way the cam automatically adjusts its internal brightness, so I turned up the "brightness" value in the "configure" settings and it worked fine on my end. It even saved fine and didn't reset or anything like some people were reporting. I'm actually really confused.
EDIT: Also I wanted to apologize for taking months to even look at this issue. I'm a total jerk.
Yea that works fine but the cam doesn't adjust the brightness automatically. When you are streaming in the evening and it's getting darker outside your picture is getting darker and darker. I know it is a marginal problem but manually adjusting the settings is only a temporary solution I think.
Greets
