Hey guys, I am getting 5.5 up but anytime I set my bitrate higher then 1800 my dropped frames start to steadily increase. Any ideas what I am doing wrong?
If so, its probably a routing/peering problem where you cannot do anything against it. Only contacting your ISP could help there. Thats what I am doing atm. On your side I would check out the thread, see whats different and whats the same between our problems and then traceroute some of the Twitch servers.
Thank you for referring me to that thread, seems like a brutal issue you have been going through. I'll keep digging through some of the items listed, thanks again.
Kay try this:
720@30fps (or lower)
scene buffering time 500
keyframe interval 2
CPU preset veryfast
max bitrate 2200-3500 (buffer same)
try different servers
Monitor CPU usage through windows resource manager/monitor while gaming+streaming. If CPU load is below 60% at all times then try CPU preset faster (if you get 100% CPU load spikes and/or dropped frames -> lower back to veryfast).
