I have now joined this forum only because I have found the solution to a problem that I have not found anywhere else yet.
I am not a big user of OBS, but have used it a lot lately. When I was checking out a new recording, I discovered that the the audio was terrible. It sounded like it was recorded inside a steel container. I'm using an old HP Pavilion and VLC as the default video player.
So I ended up trying everything that has been suggested here and on youtube, but most of the advices has been a total waste of time. But luckily some have been partially helpful.
Those who have been totally useless in this case:
* Checking the sound settings in windows and OBS
* Filtration
* Run Apple Application Support for 32 and 64 bit
* Control settings (from 7.1 audio to stereo, etc.)
* Update of OBS
* Update of VLC with current settings
What has been partially helpful:
* Checking the Log Files
* Change the file format from mp4 to MKV
None of these solved the problem, but they provided important clues as to where the problem was.
The log file informed me that there was a problem with VLC.
" Couldn't find VLC installation, VLC video source disabled "
When the file format was changed, the video file was opened in a program other than VLC., and the sound was perfect In this program.
The solution:
* Update of VLC without current settings
It turned out that the settings in the VLC had at one point changed or been changed. I can't tell what settings this has been since everything is working as it should at this moment.
Current Log File says
" VLC found, VLC video source enabled "
* Filtration
* Update of OBS
The solution:
