Audio stuttering | AverMedia Stream Engine
FaqRaviolo
I just bought AVerMedia’s LGP Lite capture card, and when I was testing it I realised that, when I set the quality in AVerMedia’s Stream Engine to 720p or 768p, the audio stutters, both for recording and for streaming. When I listen to the captured audio it sounds just fine, that’s why I imagined it’s a problem with OBS. It also happens only for 720p and 768p video, out of the resolutions I have tried (I didn’t have any problems with 1080p or 360p), and framerate makes no difference.
In the source properties, if I choose “Output desktop audio” in Audio Output Mode I can hear it correctly, but when it’s set to “Capture audio only”, the audio stutters again.
Does anyone know why this could happen? Has this or something similar happened to someone else? Do you know how to fix it?
Thanks in advance, cheers!
The videos in 1080P, 720P and 360P configurations on Stream Engine:
1080 (ok):
720 (bad audio):
360 (ok):
