Question / Help Audio Problem with USB Mixer
BardoInsano
Hello,
I've been getting a problem trying to use OBS with my USB Audio Mixer, it is a Behringer Xenyx 302 USB.
I use it with a condenser mic Behringer C3, with a Monster XLR Cable.
In other softwares that i tryied the audio is just fine (audacity & logitech softwares), on OBS the preview it's fine too, however while recording or streaming, i get something weird on the audio, from time to time, with no pattern it starts do "fail" the audio, then goes mute, and finaly comes to normal, and repeat the problem...
I'm using windows seven x64, i've tried use OBS X86 e X64, none, i'm using the x64 codec of the mixer.
There's no error log from this.
Only once it worked propperly, and i didn't chance anything to make it do so...
Some people recomended try using the analog out to record, however my laptop have no mic input, that's why i get the USB mixer.
Could someone help me, please?
I Thank you in advance for your time and good will! And Sorry for my Poor english, hope you can understand the problem.
Hello,
Thanks for your quick response, infortunatly i'm not in the streaming laptop right now, however i made some tests and reasearch early and i think i fixed it.
I read in the forum someone saying that have a problem with usb headset mic, and then, the problem was with buffering, i tried changing my buffer, and reduce, a lot my bitrate (when recording instead of streaming i use to let the "raw" recording with an extremely high bitrate to try to reduce loss with edition and conversion.
Aparently it worked, i've tried some times to start, close, start, stop and start again, and no more problem.
if you like, i could send you the log tomorrow, i don't known if it would help the project in somehow...
Anyway, thanks a lot for your quick response!
