Audio Monitor Filter not showing
Omar Saleh
Hi,
I've installed VB-Cable A + B on my Mac, in order to send OBS audio (out) to Zoom or Webex (in) and use it as a microphone in the conferencing platforms. However, the audio monitor doesn't show up in filters when trying to do that (screenshot below).
Can anyone advise please on how to get the audio monitor added to OBS, so that I can then use VB cable with it?
Many thanks!
Omar
Emet
Hello Omar,
I had this problem when I downloaded and installed the 0.8.1 version (latest) on my PC. So I uninstalled it and downloaded the previous version (0.8.0) instead. After installation it worked.
So not exactly a fix but a workaround.
Cheers.
