Question / Help audio loop, audio echoes
Most common causes are: having your own stream open in a window; using your default audio device for monitoring.
A logfile might help diagnose. The above are the most common causes. Just letting a stream run several hours won't cause a properly configured stream to begin doubling audio.
If could also be that your audio is doubled all the time, but it's not noticeable immediately because both sources are in sync. If after several hours the two sources of audio fall out of sync, that would then become noticeable.
I'll talk to her tomorrow and ask for a print screen from Advanced Audio Properties and Settings> Audio
